Old 02-04-2014, 05:54 PM   #1
Zable49
Zable49's Avatar
A-arms
Ok folks, just curious.
3/4 ton 75-86 lower and upper a-arms are the same as 67-72 3/4 ton a-arms correct?
1970 C20 Camper Special
SBC350 / TH350
'84 C20 Front Disc Brakes/Control Arms
Zable49 is offline   Reply With Quote
Old 02-04-2014, 07:23 PM   #2
hugger6933
Re: A-arms
Don't think so. The 67-70 maybe had a different LCA. Hollender also list a different lower control arm for the 71 -72 model years. I know this from researching a 6 bolt disc brake upgrade using all stock parts. I also know that using the 68ish LCA [Iknow that year in particular because I have one of those with leftover parts]and the stock uppers a person can bolt in the ball joint for a 88-98 7200GVW 3/4ton and on the lowers press in the balljoints for the same truck and then your able to use that spindle and caliper. In effect giving you a factory type 6 lug disc brake front . Jim
hugger6933 is offline   Reply With Quote
Old 02-04-2014, 07:29 PM   #3
airdale94
airdale94's Avatar
Re: A-arms
67-87 3/4 ton upper control arms interchange. The difference in the lowers is the disc brake spindle turn stop. The disc brake spindles take a different ball joint. But will install in either. Same for the uppers.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 02-04-2014, 07:51 PM   #4
Zable49
Zable49's Avatar
Re: A-arms
Well I guess I should check to make sure I have that stop because the PO put discs on the truck few (10 ish) years ago from a newer truck and I dont know if he changed the arms or just spindle.
SBC350 / TH350
Old 02-04-2014, 10:07 PM   #5
Zable49
Zable49's Avatar
Re: A-arms
Well since I guess the PO did change out the arms also since I have the "STOP" on them.. So knowing that I guess the whole front suspension is from the 84.
SBC350 / TH350
Old 02-05-2014, 02:26 AM   #6
68shortfleet
Re: A-arms
The drum brake and disc brake arms all have a steering stop on them. The location of the "stop" is different for disc. SO, you may not have 84 arms...
68shortfleet is offline   Reply With Quote
Old 02-05-2014, 03:31 AM   #7
Zable49
Zable49's Avatar
Re: A-arms
So the only way to find out would be to go find a set of 84's and do a side by side comparison...
SBC350 / TH350
Old 02-05-2014, 12:01 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: A-arms
Your upper arms are definitely 73 and newer. You can tell by the slotted bolt holes on their front sides where the brake line bracket bolts to. These slotted holes were lacking in 72 and earlier arms.
My money says since you have later model uppers and later disc brakes, that the lowers are later too. It would only make sense.
Old 02-05-2014, 05:46 PM   #9
airdale94
airdale94's Avatar
Re: A-arms
I can't remember the difference between the 2 lowers. You will either have to much turn and the tires will rub. Or not enough. The springs for the 73-87 are about 1" taller than the 67-72 drum. Both will fit and work. I used the 73-87 and after I was done chased a excessive camber issue on the left side. After some work I discovered I had a weak spring on the right. I thought maybe I mixed them up. Took it apart measured them, sure enough left side 1" taller. Did some other stuff came back measured them again, same length. Now what! Course I allready told you I "discovered" actually deduced I had a weak spring on the right. Anyway I ordered a new set (got the 68 drum) and installed them. Ah fineally! Camber perfect.
Old 02-05-2014, 06:28 PM   #10
67 cst swb
67 cst swb's Avatar
Re: A-arms
those would have to be 3/4 ton arms... my memory is only 3/4 & 1 tons had the early style bushings like in the picture he provided
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-05-2014, 09:47 PM   #11
Zable49
Zable49's Avatar
Re: A-arms
Well to make things easier, I will just pickup ball joints and bushings for the '84 and if they dont fit correctly I will just return and order the older style.
SBC350 / TH350
