02-04-2014, 05:56 PM | #1 |
Where do you guys buy braided brake lines from?
I have been having problems with the front brakes dragging. It was brought to my attention the original brake lines could be collapsing so I thought that I should go ahead and go with braided in the process. Who is the best to purchase them from? Is there a vender on here that sells them?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
02-04-2014, 06:08 PM | #2 |
Re: Where do you guys buy braided brake lines from?
I cant remember where I got mine from but they a very noticeable difference on my 86 c10.
02-04-2014, 07:06 PM | #3 |
I got a set with my lift from offroaddesign.com. They look like quality lines, but I haven't installed them yet, so I can't tell you how much of a difference they make.
02-04-2014, 08:34 PM | #4 |
Another Day, Another Dollar
I get em up here through a hydraulic equipment hose supplier called greenline. Not sure if they are operational south of the border
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
02-04-2014, 10:19 PM | #5 |
At the body shop.
Lifted I'd look at 4wp or Summit
" That didnt make it any newer " " Dont antique the equipment " |
02-04-2014, 10:20 PM | #6 |
inline tube
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
02-04-2014, 11:17 PM | #7 |
Thanks for all of the input! I was looking at a set of Russell brand on Ebay. They are $98 I was just hoping maybe a vendor here on the board sold them.
02-04-2014, 11:48 PM | #8 |
What Hump?
There is place over by 19th ave & Lincoln, downtown the are called something tubes I cannot remember since its been several years.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
02-04-2014, 11:56 PM | #9 |
I will check them out! Thanks!
02-04-2014, 11:59 PM | #10 |
Could it be Arizona Tubes at 2034 W Jackson?
02-05-2014, 12:20 AM | #11 |
I got a full set for $75 I believe of summit. Russel DOT lines. Made a big difference in mine too. I will see if I can find the part number.
My stepside brakes were dragging and not releasing. I dug into the issue and found the cause. The issue isn't the lines collapsing but rather expanding and the metal sleeve that holds them on will restrict one section from expanding so it swells shut inside.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-05-2014, 01:01 AM | #12 |
same here, got them at Summit
Skyjackers DOT, 'bout 8" longer than stock-$170 for all 3 plus they come with new everything, diff size adapters, washers, brake block, etc |
02-05-2014, 01:24 AM | #13 |
What Hump?
Yes that sounds like the area. My son had them made foor his 4 x 4 the bright orange one posted on the forum but that has been almost eight years now, and they came out really nice.
tom
