Old 02-04-2014, 10:43 PM   #1
matt_field
matt_field's Avatar
1968 k10 rear leaf spring shackle bushings needed!
Hey guys, do you know if anyone makes a shackle bushing for the rear of a 67-68 4x4 ?? I can't find anything. This truck I'm restoring it to original so I'm not switching brackets on the frame . Thanks!
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 02-05-2014, 01:08 PM   #2
61K10
61K10's Avatar
Re: 1968 k10 rear leaf spring shackle bushings needed!
different than 60-66? lmc sells the 60-66.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-05-2014, 01:24 PM   #3
54blackhornet
54blackhornet's Avatar
Try off road design in CO.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-05-2014, 01:37 PM   #4
matt_field
matt_field's Avatar
not sure if 60-66 is the same or not, i know mine are roughly 2.5 length, 1.5 diameter.
I thought about buying some leaf spring bushings that same diameter and turning them down in a lathe to my length i need.
Matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 02-05-2014, 05:58 PM   #5
argonaut
argonaut's Avatar
Are they bronze bushings or rubber? If LMC doesn't have them you might have to machine your own. But be aware they need holes and slots for grease distribution.
Also, on my 66 the original bronze bushings had been completely worn through and had also worn the steel of the shackle and hanger so they were no longer round. In this case a stock bushing would no longer work.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
