Old 02-04-2014, 10:58 PM   #1
19GM71
19GM71's Avatar
Where to find auto-column shift levers
I just restored a van tilt column, a 68 truck steering wheel and installed them in my truck. I bought a tilt lever and turn signal lever kit from Speedway to dress it up a bit. The shift lever was in bad shape, so I painted it silver for now. I am having one heck of a time finding a shift lever that is similar to these. So I thought I would reach out to you all for some help. Where can I find these shift levers?
19GM71 is offline   Reply With Quote
Old 02-05-2014, 12:33 AM   #2
davischevy
davischevy's Avatar
Re: Where to find auto-column shift levers
H&H Classic at Bentonville, AR has them in their catalogue.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 02-05-2014, 12:41 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
We have many great board vendors that carry both the levers and the knobs.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 02-05-2014, 08:32 AM   #4
19GM71
19GM71's Avatar
Thank you for the information. I am still learning to navigate the board, so I will be checking out our board vendors.
Old 02-05-2014, 11:14 AM   #5
jmking9
jmking9's Avatar
You have yourself one sharp looking truck there!
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 02-05-2014, 11:20 AM   #6
19GM71
19GM71's Avatar
Thank you very much! I appreciate the compliment.
Old 02-05-2014, 03:05 PM   #7
davepl
davepl's Avatar
If you find a link to a vendor, please let me know. The repops from LMC and so on have a really ugly knob with casting flash, besides being a completely different style as well.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-05-2014, 04:35 PM   #8
19GM71
19GM71's Avatar
If I can figure out how to navigate the vendors section I will let you know. I am new here so I haven't learned all the ways around the board yet. If anyone can guide me I would appreciate it. Thanks
Old 02-05-2014, 08:33 PM   #9
AirSpeed
AirSpeed's Avatar
I made my own, cast it out of scrap aluminum. The original stuck out too far when I replaced my steering wheel. I also cast a shift know for my transfer case.
AirSpeed is offline   Reply With Quote
Old 02-05-2014, 11:47 PM   #10
davischevy
davischevy's Avatar
Give us details about casting. How you did it.
other Larry
Old 02-06-2014, 12:35 AM   #11
AirSpeed
AirSpeed's Avatar
First you need to build one of these, a foundry, I built mine out of a propane bottle lined with a home made refractory, made out of clay, sand and styrofoam balls, gets mixed up then I poured it into a form inside the propane bottle, once it drys I fired it melting all the styrofoam leaving thousands of tiny insulating pores. Made the burner out of pipe that fits in a tube to mix air/fuel, I used a mig tip as the jet.
It heats up to about 2000 f, the refractory glows bright. I use a small propane bottle as a crucible for melting aluminum. I then cut the shape I want to cast out of styrofoam, stick foam sprues to the patter, bury it in sand then pour the molten aluminum into the sprues, the foam pattern melts and is replaced with aluminum. Let it cool, sand it and it's done.
This was one of my earliest attempts to cast aluminum, I'm getting into pattern casting now which is more precise. I've made a bunch of stuff casting aluminum including these cam clamps for my my bike
And this light. It's a lot of fun.
Old 02-06-2014, 11:36 AM   #12
davischevy
davischevy's Avatar
Looks like we, very effectively, highjacked a thread.
Thanks, Your very industrious, keep up the good work. Are you in the foundry or mold industry? Harrison, where I live, has several foundries and mold shops for both plastic and aluminum.
other Larry
Old 02-06-2014, 07:21 PM   #13
AirSpeed
AirSpeed's Avatar
No, not in the foundry industry, I just like making my own stuff, I'm set up to anodize and am now setting up a chrome plating system. Monday I get my new CNC! This stuff is really easy to do, I was surprised how much serious money I've saved since learning how to cast aluminum. Thanks.
