Old 02-04-2014, 11:23 PM   #1
Pinsco63
Pinsco63's Avatar
3/4 ton track bar mount
I have a 63 3/4 long bed with coil springs. I want to keep the trailing arms and am replacing the eaton with a 14bolt ff. My only problem is coming up with a track bar mount that I can weld on the axle housing. The original eaton still has the mount that I can try to cut off but thought if I was able to get a new mount it would make life a lot easier. Any help is much appreciated. I will try to post pics tomorrow. thanks guys
1963 c/10 Changed to 3/4ton 292ci Borg t98
1965 Buick Skylark 300ci TH350
1976 AMF Shovelhead 4 Speed
1982 K20 4x4 454ci sm465
1991 GMC k20 Suburban 4x4 350ci 4l80e
1999 GMC Jimmy 4x4 262ci 4l60e (wife's rig)
Pinsco63 is offline   Reply With Quote
Old 02-05-2014, 02:52 AM   #2
Captainfab
60-66 Nut
Re: 3/4 ton track bar mount
If you are planning on using the original panhard bar, then cutting the mount off of the Eaton is your best bet. I do make the trailing arm mounts for the 14 bolts, but I have not gotten around to making the panhard bar mounts yet. Most guys just cut the original off of the Eaton.
