Old 02-05-2014, 02:44 PM   #1
truckdude239
truckdude239's Avatar
oil sender?
what are the thread size of the stock sender? i'm wondering if i can use the stock 71 oil line and fitting with the ls motor
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-05-2014, 03:05 PM   #2
akdg87
akdg87's Avatar
Re: oil sender?
thread size is m16 x 1.5, i bought this assortment from summit because i needed a water temp sensor adapter as well and this was cheaper than the other alternatives (like the autometer adapters which are spendy- $11 each): http://www.summitracing.com/parts/sun-cp7573
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 02-05-2014, 03:26 PM   #3
wgeyer88
Re: oil sender?
I'm following what LS1NOVA did. No need to buy anything and it only takes a few minutes to do! I think the original oil line is 1/8 NPT, but not 100% positive.
http://ls1tech.com/forums/16774255-post26.html
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 02-05-2014, 09:48 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: oil sender?
I did the drill and tap for the temp sensor. wasn't hard...just take it slow.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-05-2014, 09:56 PM   #5
crazy longhorn
Fabricate till you "puke"
Re: oil sender?
I have done a bit of fab work(a bunch)... but figure that time is money? I spent the $11 bones on the screw in deal....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-05-2014, 09:58 PM   #6
truckdude239
Re: oil sender?
Im just trying to get my basic gauges running till i get the money for dokata digitals
David fuller
2000 Tahoe 5.3l 378
Old 02-06-2014, 12:10 AM   #7
lynnfield
The Waco Kid
lynnfield's Avatar
Re: oil sender?
I ran into this same problem today. I called classic instruments, they said to drill out the port on the little aluminum block located above your oil filter with an 11/32 bit and tap it with a 1/8 npt. Greg
lynnfield is offline   Reply With Quote
Old 02-06-2014, 12:52 AM   #8
66LSx
66LSx's Avatar
Re: oil sender?
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 02-06-2014, 04:12 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: oil sender?
Not everyone has that GOOFY HUGE sender tho... lol
They make the blockoff/bypass in three styles.
The blockoff style, which is a flat plate with a "nipple" on it, that can be drilled and tapped carefully. Only hard part is getting the tap square so it taps straight threads.
The second style has the removeable plug, which is the one in that picture. It didn't come on as many vehicles, and it now shares the same catalog part #'s as the next one.
Third style is the same as above, but not tapped/plugged. It has the elbow with a flush surface and is easy to tap.
There are a few billet pieces on the internet as well, which are pre-set for AN fittings if you need that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-06-2014, 10:35 AM   #10
66LSx
66LSx's Avatar
Re: oil sender?
Not mine... just did a google image search and it was the first thing that popped up...
Just spoon feeding now before I start leeching information back out.
1966 C10 SWB Fleet
Old 02-06-2014, 12:19 PM   #11
solidaxel
solidaxel's Avatar
Re: oil sender?
I know it is GOOFY and Huge But there was no cost, as it came from the 350 I removed that was hooked to the gauge in the truck, so I know what it should read.
Cost $0 tome less than 15 min!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-06-2014, 02:45 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: oil sender?
Hawks put my goofy one in the stock location.
You want ever see it unless you are really looking for it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
