Old 02-05-2014, 06:27 PM   #1
Snydcat
Radiator ?
I've been looking at the 3 Rows/cores Performance aluminum radiators for my 66 I6 250 and the sellers claim they are a Direct Bolt-On OEM Fitment or Replacement for I6 and V8. Has anybody installed one and did you have to do any modifications to get it to fit.
Thanks,
Rich
Snydcat is offline   Reply With Quote
Old 02-05-2014, 07:21 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Radiator ?
I bought a Champion one from the Fleabay seller located in Portland, OR and it fit perfect, works great and will continue to buy from him ( great customer service)
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-06-2014, 10:50 AM   #3
65chevygal
65chevygal's Avatar
Re: Radiator ?
I also bought a Champion and I'm happy with it, my only comment is that the Champion radiator does not fit in the original radiator brackets and it doesn't come with brackets. I had a friend fabricate new lower brackets and he modified the top bracket to work.
65chevygal is offline   Reply With Quote
Old 02-06-2014, 01:07 PM   #4
Snydcat
Re: Radiator ?
I just ordered this one http://www.autopartsandstuff.com/spe...FTJp7AodpzAAHQ shouldn't have to do any modificatons to the brackets ( fingers crossed ).
Thanks,
Rich
Old 02-06-2014, 01:15 PM   #5
Billett
Billett's Avatar
Re: Radiator ?
I got a champion from a vendor here. It didn't fit perfectly, but it worked just fine after I ground down the stock mount just a bit.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-06-2014, 02:04 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Radiator ?
I also have a champion and it fit other than I wittled down the lower mount bushings a bit
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-06-2014, 03:09 PM   #7
wayno
Re: Radiator ?
I too installed a champion - fit like a glove and only had to whittle down the upper rubber bushings...
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 02-06-2014, 09:50 PM   #8
OldTrucksRule
Re: Radiator ?
I had cooling problems with the BeCool radiator because I have a big block and went to an electric fan. I am now of the thought that I should have gone to a radiator shop before and had one custom made which is what I ended up doing. Dumped the electric fan for a mechanical because, lets face it, I'm not racing, just driving, and I don't want to have to worry about cooling. All is well now.
OldTrucksRule is offline   Reply With Quote
Old 02-07-2014, 08:44 AM   #9
Sharps40
Re: Radiator ?
I have been totally well served by this brass radiator from Advance Auto. Its for the V8, fits the V8 mounts and I've used it on my 283 V8 and now on my 250 I6. It is a 3 core. Installation on the I6 is detailed in one of my John Lee threads, believe its captured in FAQ. You can use the factory style I6 lower hose and I listed part numbers for both upper and lower radiator hoses in the install thread. You could make the air dams from scratch when converting from the small 6 rad to this larger v8 rad. Either make a new top clamp or junkyard for the v8 style.
Code P20 on an internet order should net you 20% off and free shipping. At a starting price, newly reduced to $196 (it was over $200 last year) another 20% and free delivery is makeing it almost worth buying another for a spare!
http://shop.advanceautoparts.com/web...hTerm=radiator
Sharps40 is offline   Reply With Quote
Old 02-07-2014, 08:47 AM   #10
Sharps40
Re: Radiator ?
Here is the link to the install thread. Makes it look factory, extra capacity and I run no shroud on the I6, works super....bout 21000 miles down the road now with this rad in two different trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=599562
Old 02-07-2014, 09:49 AM   #11
kieth
kieth's Avatar
Re: Radiator ?
I have the same 3 core, got it from rock auto 3 years ago, about $175.00 20% off of 196.99 is not a bad deal...... works great with a mild 350...tbi and no shroud.....
kieth is offline   Reply With Quote
Old 02-07-2014, 10:04 AM   #12
Sharps40
Re: Radiator ?
Yep, drops the price to $157....plenty to buy some flat steel stock and make up lower/upper mounts and some sheet metal for the dams if yer goin from small 6 rad to this wider model
Old 02-07-2014, 12:03 PM   #13
Snydcat
Re: Radiator ?
I just looked at your install and by the looks of it I already have the bigger radiator in it....so I shouldn't have to do any bracket modifications.
Old 02-07-2014, 12:18 PM   #14
Sharps40
Re: Radiator ?
Cool beans! Nothin like havin an Easy Button.
Old 02-10-2014, 11:58 AM   #15
SparkyRnD
SparkyRnD's Avatar
Re: Radiator ?
we make a bolt-in radiator for your truck, and we make them here in the USA. We are also a supporting vendor here and offer a discount for forum members:
http://67-72chevytrucks.com/vboard/s...d.php?t=591690
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 02-10-2014, 12:49 PM   #16
rideblue00
rideblue00's Avatar
Re: Radiator ?
that looks really nice Sparks!!
rideblue00 is offline   Reply With Quote
Old 02-10-2014, 12:53 PM   #17
rideblue00
rideblue00's Avatar
Re: Radiator ?
ill check your link, but what is the width on your tanks?
Old 02-10-2014, 01:22 PM   #18
SparkyRnD
SparkyRnD's Avatar
Re: Radiator ?
our tanks are made to the same dimensions as stock so that they can utilize the stock mounting brackets
Old 02-10-2014, 02:06 PM   #19
Clyde65
Clyde65's Avatar
Re: Radiator ?
Sparky, do you do stuff like in/outlet size changes and steam port installs for us with LS engines???
Clyde65
Rebuild of Clyde
support our troops!
Old 02-10-2014, 02:22 PM   #20
SparkyRnD
SparkyRnD's Avatar
Re: Radiator ?
Yes, we do that stuff daily. Every LS conversion gets the ports in the correct size moved to the passenger side, and we add a steam port all at no additional charge. Also, we include a built-in trans cooler when requested at no additional charge.
Old 02-10-2014, 04:46 PM   #21
Snydcat
Re: Radiator ?
Thanks,
Rich
I just got this radiator and it's plastic on top and bottom ...I'm sending it back.
Old 02-10-2014, 04:58 PM   #22
Trump
Re: Radiator ?
Sparky's radiator looks very nice, if you are after aluminum.
If you are after a more traditional looking one, I bought one from Advance Auto Parts recently. It is called "Tough One Ready Rad" Part #: 433284
It is a little more than the Spectre one, but has the real metal tanks. Seems to be a quality piece.
You can usually get it cheaper.... Advance auto runs monthly deals, usually 15-20% off online orders and free shipping on orders over $75. Then if you use Discover Card, they are a retail partner and you get another 5% in cash back if you go through Discover's website to order. So if you are smart, you can level the playing field pretty quickly.
Trump is offline   Reply With Quote
Old 02-10-2014, 05:07 PM   #23
SparkyRnD
SparkyRnD's Avatar
Re: Radiator ?
Thanks Trump. We have had a few guys ask if we do the stock looking tanks, but we only make them out of fabricated aluminum (thicker than the stamped stuff). A few folks have painted them black to get more of an original look. Our price is going to be higher than the imported stamped stuff, but then again for a quality, Made in the USA product, we're ok with that.
Old 02-10-2014, 05:28 PM   #24
Snydcat
Re: Radiator ?
That's exactly what I just did and it's in stock at the local Advanced Auto...should of did this do begin with..live and learn I guess.
Old 02-10-2014, 05:55 PM   #25
doobiebro
doobiebro's Avatar
Re: Radiator ?
Purchased a 3 core Champion 3 years ago and it fits like a glove... 60-63 bolt right up on the radiator support. Very happy with the product..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
