Old 02-05-2014, 07:35 PM   #1
silverbear
silverbear's Avatar
86 K10 LWB - Frankie
I just recently joined this forum. Heard great things about the people here I have already gleaned some valuable information from other builds.
I purchased this truck in January of 2013 and I have already completed a lot of work but I took pictures along the way so I can share my story. This is my second 86. The first was a C20 GMC who underwent lots of surgeries and when I sold it back in 1998 it had been converted to a 4 wheel drive and had body and drivetrain parts from about 6 different trucks. I called him Frankenstein. This Chevy K10 has earned the name Frankenstein Jr or Frankie. You will see in the pictures that from a distance the body did not look to bad but as I got into it, I found RUST and lots of it.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 02-05-2014, 07:44 PM   #2
silverbear
silverbear's Avatar
Re: 86 K10 LWB - Frankie
I had a brake line bust and in the process of running all new steel tubing from the front proportioning valve out, I decided it was time to change out the front fenders. This seemed to be the easiest way to gain access to the front frame. Had to replace the fuel lines while running the brake lines as they were rusted out too. I did not take any pictures of the new lines, just lots of pics of RUST.
1996 GMC Yukon GT
Old 02-05-2014, 07:51 PM   #3
silverbear
silverbear's Avatar
I was trying to put the truck back together so I could actually use it but I was plagued with clutch issues.
These pictures were taken on 2-15-13
1996 GMC Yukon GT
Old 02-05-2014, 07:59 PM   #4
silverbear
silverbear's Avatar
I was being optimistic about fixing the clutch issues so I pressed on putting the front clip back together.
Pic taken 2-21-13
1996 GMC Yukon GT
Old 02-05-2014, 08:04 PM   #5
silverbear
silverbear's Avatar
My $100 craigslist find. Has a couple dents but no rust.
1996 GMC Yukon GT
Old 02-05-2014, 08:18 PM   #6
silverbear
silverbear's Avatar
Another craigslist find. Has some surface rust on the roof and pillars but at least the floor and firewall are solid.
Pics: 3-20-13
1996 GMC Yukon GT
Old 02-05-2014, 08:23 PM   #7
silverbear
silverbear's Avatar
With a replacement cab sitting on the trailer, I decided the easiest way to work on the trans/clutch was just to get rid of the old cab. Front clip came back off. I started to sand the frame and paint it.
Pics: 4-8-13
1996 GMC Yukon GT
Old 02-05-2014, 08:37 PM   #8
silverbear
silverbear's Avatar
Got the bed out of the way.
Pics: 4-13-13
My wife "convinced me" that I should just sand blast the frame instead of sanding it.
Frame sand blasted and primed
Pics: 6-16-13
1996 GMC Yukon GT
Old 02-05-2014, 08:41 PM   #9
silverbear
silverbear's Avatar
And a little paint.
Pics:6-17-13
1996 GMC Yukon GT
Old 02-05-2014, 08:46 PM   #10
silverbear
silverbear's Avatar
Set the new cab on the frame. Now onto the body work.
Pics: 6-22-13
1996 GMC Yukon GT
Old 02-05-2014, 08:53 PM   #11
silverbear
silverbear's Avatar
A little rust to address.
Progress.
Pics: July to August 2013
1996 GMC Yukon GT
Old 02-05-2014, 09:01 PM   #12
silverbear
silverbear's Avatar
Lots of sanding and a little bit of primer.
Pic: 11-16-13
Had to do something to make me feel like the project is still moving along even though the budget has vanished.
Pics: 1-5-14
1996 GMC Yukon GT
Old 02-05-2014, 09:08 PM   #13
silverbear
silverbear's Avatar
Got a few more parts put on. I know the core support is not want I wanted to re-use but the budget says that's what I have to do for now.
Pics: 1-11-14
1996 GMC Yukon GT
Old 02-05-2014, 09:14 PM   #14
silverbear
silverbear's Avatar
This is where I am at currently and you may be understanding why I have name this truck Frankie (Frankenstein Jr).
More to come...
1996 GMC Yukon GT
Old 02-05-2014, 09:19 PM   #15
Jeffp1979
Do you still have the 3/4 front spindles and rear end?
Jeffp1979 is offline   Reply With Quote
Old 02-05-2014, 09:27 PM   #16
silverbear
silverbear's Avatar
Sorry those parts are long gone.
1996 GMC Yukon GT
Old 02-21-2014, 09:35 PM   #17
silverbear
silverbear's Avatar
Weather cooperated a bit today so I was able to finish up prepping the gas tank to go back in. Maybe tomorrow if the ground is dry enough I will get this hanging off the frame once again.
1996 GMC Yukon GT
Old 02-21-2014, 10:31 PM   #18
Greenlee
Greenlee's Avatar
Nice work! You have made a lot of progress.
Greenlee is offline   Reply With Quote
Old 02-23-2014, 12:04 PM   #19
silverbear
silverbear's Avatar
Got the exhaust welded up and temporarily hung. I need to make some mods to the bump stop brackets to give enough clearance for the mufflers to fit up higher in the frame. I was worried I would not have enough clearance for the X pipe, but even hanging low where it is at gives me almost 10 inches between the pipes and the drive shaft. I still have to add tail pipes but this is enough exhaust that I can run the truck until I figure out what I want to do. I am thinking about running the tail pipes straight out the back right through the bumper. My current bumper is rusted out so now will be a good time to experiment.
I also got the gas tank hung back in place.
1996 GMC Yukon GT
Old 02-23-2014, 02:00 PM   #20
rs74
rs74's Avatar
Looks like you have done quite a bit of work on it already. What color do you plan on painting it. The Midnight Blue on the bed is a nice color that I would like to see on a truck of mine.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-23-2014, 03:57 PM   #21
silverbear
silverbear's Avatar
I was thinking silver but have also considered going back to the original copper.
1996 GMC Yukon GT
Old 02-24-2014, 09:57 PM   #22
silverbear
silverbear's Avatar
Problem: Tall radiator...short radiator shroud.
Solution: Had some scrap stainless laying around. I still need to polish it up but I want to make sure it fit.
1996 GMC Yukon GT
Old 03-12-2014, 09:26 PM   #23
silverbear
silverbear's Avatar
After sitting for about a year, I was very excited to turn the key and after priming up the fuel lines, the engine fired up. My new exhaust sounds excellent (even though it is not complete). So many details to address but I am anxious to actually drive this beast.
1996 GMC Yukon GT
Old 03-19-2014, 09:40 AM   #24
bgood70
bgood70's Avatar
Talking Re: 86 K10 LWB - Frankie
Attachment 1210795
Attachment 1210799
Attachment 1210800
My Ford looks so good pulling that Chevy... Sorry just had to say that....
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 03-19-2014, 09:43 AM   #25
silverbear
silverbear's Avatar
I won't argue that. I did enjoy that trip even though we froze our butts off.
1996 GMC Yukon GT
