Old 02-05-2014, 11:35 PM   #1
mrkidd
71 front end on c10 will other spindles work
i have a 54 chevy 3100 its has a 67 c10 frame with a 71 disc brake setup...im looking for drop spindles , will only 72-71 spindles work or can i go newer years...thanks for the help...
mrkidd is offline   Reply With Quote
Old 02-05-2014, 11:41 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 71 front end on c10 will other spindles work
71-72 only.
Keith
Convert to disc brakes.
Old 02-06-2014, 08:32 PM   #3
mrkidd
thanks very much
Old 02-08-2014, 04:04 PM   #4
GEARBOXGARAGE
You can use '73-'87 spindles by changing out the upper ball joints to the same. '71-'72 uses the same lower ball joint as the '73-'87, which are pressed in. The uppers were riveted in, but the replacements come with 4 bolts to replace them. From what I understand, GM went to a larger ball in the upper ball joint in '73 and thus increased load capacity. If you are in a position to replace any ball joints while doing the spindle swap, it may be something to consider.
GEARBOXGARAGE is offline   Reply With Quote
Old 02-08-2014, 04:41 PM   #5
lolife99
lolife99's Avatar
You will also have to change your 71-72 outer tie rod to a 73-87 version if you use 73-87 spindles.
Keith
Old 02-08-2014, 04:44 PM   #6
GEARBOXGARAGE
Good point, lolife99. Thanks for adding that info!
