Old 02-05-2014, 11:47 PM   #1
cigar-
cigar-'s Avatar
steering wheel
Does anyone know if there is a spring that is to be placed under the wheel before placing it on the steering shaft?
I have a basket case of a column and am trying to re-assemble it. So far I am left with parts that look like they might go on but I don't know. I have the CD-ROM that shows the original catalog of parts from Chevrolet but that doesn't show a 1971 column exploded with all parts.
Michael
cigar- is offline   Reply With Quote
Old 02-05-2014, 11:54 PM   #2
kcsa75
kcsa75's Avatar
Re: steering wheel
Does this help?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 02-06-2014, 12:05 AM   #3
FirstOwner69
FirstOwner69's Avatar
Re: steering wheel
There is a spring that goes under/behind the turn signal switch. It's shown on this LMC page as not available.
FirstOwner69 is offline   Reply With Quote
Old 02-06-2014, 12:15 AM   #4
cigar-
cigar-'s Avatar
Re: steering wheel
I just happen to have two of those springs. The problem is that when I place it under the wheel and turn signal cam, it makes it VERY difficult to get the wheel onto the column far enough to start the nut that holds the wheel down.
Old 02-06-2014, 12:16 AM   #5
cigar-
cigar-'s Avatar
Re: steering wheel
I only wish I could find someone in SoCal from this site that is knowledgeable about these trucks! I could use the education and help.
Old 02-06-2014, 12:17 AM   #6
cigar-
cigar-'s Avatar
Re: steering wheel
I do have the LMC catalog and I do see where it shows the spring....
But thanks for the help any ways.....
Old 02-06-2014, 12:20 AM   #7
FirstOwner69
Re: steering wheel
It does take a bit of pressure. It's a pretty robust spring. It might help if you can measure the length and post a pic of your spring(s).
Old 02-06-2014, 12:59 AM   #8
SS Tim
SS Tim's Avatar
Re: steering wheel
If you don't have a service manual get one. Usable copies can be downloaded from the link inmy signature.
SS Tim is offline   Reply With Quote
Old 02-06-2014, 07:45 AM   #9
OhioDan
OhioDan's Avatar
Re: steering wheel
Is the spring at the bottom end, where it comes out the firewall, under the hood compressed? (#19)If not, compress that spring and push the whole shaft up into the column, and it might allow you enough to put the wheel nut on?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 02-06-2014, 08:04 AM   #10
19GM71
19GM71's Avatar
Re: steering wheel
I think this might help. I don't have any pics so I'll try to explain it. There is a fairly heavy spring (1 inch long, maybe 3/4 inch around) that goes on underneath the canceling cam. It should go like this; spring, canceling cam, steering wheel, then the nut. And you have to push down on the steering wheel to compress the spring while starting the nut. I hope this answers your question.
19GM71 is offline   Reply With Quote
Old 02-06-2014, 01:44 PM   #11
FirstOwner69
Re: steering wheel
Oops... I meant to say cancelling can, not turn signal switch in post #3. Hope that didn't mislead you.
