Old 02-06-2014, 01:14 PM   #1
Hampshire
Hampshire's Avatar
Lowering the rear suspension on a 3600
49 3600, 3/4 ton 8 bolt set-up is now gone....Changed to Must II IFS - The FE is done, except for final height adjustment.
Now we are removing the RE and replacing it with a 74 Nova 3:73 Posi. Only looking to drop between 1-2 " in back.
Seems to be trial and error...Would you remove a leaf, de-arch or get new? Does anyone start with an eyelet to bottom of spring bundle measurement and go from there?
Hampshire is offline   Reply With Quote
Old 02-07-2014, 12:17 PM   #2
Hampshire
Hampshire's Avatar
Re: Lowering the rear suspension on a 3600
Well...apparently no interest in this problem... BTW, putting the axle on top of the springs lowers the truck more than we want...
Old 02-07-2014, 03:21 PM   #3
Hogger54
Hogger54's Avatar
When I swapped my rear end out, I pulled about 3 leafs plus the helpers. I think it came down about 3".
Just depends on the condition of your leafs. Make sure they aren't broken, cracked, or too worn out.
Hogger54 is offline   Reply With Quote
Old 02-07-2014, 04:14 PM   #4
Hampshire
Hampshire's Avatar
...the leaves are in good shape & there are no helpers. Plan "A" is to pull one leaf & see what we get, then....
