Old 02-06-2014, 02:50 PM   #1
Hugh Mongus
Transmission question
I was going to change the fluid and filter in my TH350 a couple of nights ago, but noticed that I cannot get the two back bolts out of the pan. The cross member is in the way. I thought about removing the cross member but there are two bolts on each side of the frame that would require lifting the cab to get them out. My truck also has a new drive shaft from the PO.
My question is, what transmission do you think would have came with it originally? I am assuming the ability to remove the transmission pan without removing the cross member would have been possible with the original configuration.
Hugh Mongus is offline   Reply With Quote
Old 02-06-2014, 03:08 PM   #2
jocko
jocko's Avatar
Re: Transmission question
just loosen the trans-to-crossmember mount bolts at the isolator so the trans is just resting on the crossmember - then gently jack up the tailshaft just enough to get to the last bolts and slide the pan out. Don't jack it up too much - and monitor fan-to-radiator clearance as you do so. Motor should rock fwd on the front mounts and the jack will hold the tail. Also monitor the slip yoke of the driveshaft, you should have several inches of travel for the d/s to slip out before you run into a problem, so the fan-radiator interface is probably most important. The furthest it can drop (off the jack) is back onto the crossmember, but watch your fingers. No telling what your truck should have come with without additional info. M49 on the SPID? Most of the automatic trucks came with TH350s. All 4x4s had TH350s I believe. TH400s more reserved for big block or special order on a small block.
Old 02-06-2014, 04:21 PM   #3
Hugh Mongus
PO scraped off the SPID.
Thanks for the help. I was afraid I might break something if I jacked up the back of the transmission. I'll try that.
Old 02-07-2014, 02:49 PM   #4
MagmaJct
MagmaJct's Avatar
Please let us know how it went. I'm about to do the same due to a leaking gasket. Pictures would be appreciated, but it's okay if you can't get any.
I go into many repairs intending to document them. I'll start out with "before" pics, only remembering the "during" and "after" pics hours after I've finished. Oops!
BTW, I have a 71 with a 350engine and 350thm transmission, and I've wondered about that frame too.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 02-08-2014, 11:13 AM   #5
D13
D13's Avatar
Same problem and same solution on my 87 700R4. What I did was jack it up and slip a small wooden block under the trans mount ot hold it up, allows swivel socket and long extension to get to it from the side. Also a good time to replace that mount, which makes the whole thing easier. Do watch your fan clearance.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-08-2014, 04:03 PM   #6
bigmac73
bigmac73's Avatar
i use a 1/4 drive socket and a universal a little tedous but it works with out jacking the tail shaft up
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-08-2014, 04:36 PM   #7
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
If you take the time to pull the cross member cut a couple of notch's in the cross member with your dremel tool or some other grinder and you will have access forever.
It can be done on the truck just more tedious
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-08-2014, 08:28 PM   #8
bigmac73
bigmac73's Avatar
also once you do get it out take the time to install a drain plug if there is not one already saves you from a nasty mess
Mike
Old 02-09-2014, 07:00 AM   #9
Hugh Mongus
I have not had a chance to tackle this chore yet. I was trying to figure out why my truck seemed to like to leave me stranded on the side of the road. After installing a new fuel pump, vacuum advance, re-timing it, and exchanging my new carb for another, I finally realized it was the coil. It only took all day to figure this out.
