02-06-2014, 03:53 PM | #1 |
Awd c10?
what would it take to make my 85 2wd c10 into an AWD c1o? has anyone done one of these yet? what is all needed part wise to build one and does anyone have pics of what was done, just curious? Thanks!
02-06-2014, 04:09 PM | #2 |
Re: Awd c10?
Well you could go with the old system. Full locked up front axels, same as the rear end, and a NP203 T case. Factory GM stuff from the 70s 4WD trucks, or do a transmission, transfer case trans plant out of a modern GM AWD SUV.
My Addiction: 1969 Pontiac Firebird 1983 K10 RCLB Silverado 6.2L Turbo 1986 K25 RCLB Sierra 1990 V3500 CCLB Silverado 1995 K2500 RCLB Cheyenne 6.5L Turbo |
02-06-2014, 04:16 PM | #3 |
Re: Awd c10?
Bear in mind alot of the new systems work off the ABS sensors at the wheel (each detects wheel speed)
The jeep quadra drive system used from 99-2004 is full mechanical. I know its not chevy but the 247 transfer case engaged as needed. The axles used gerotor style limited slip differentials. This is more for an idea however
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
02-06-2014, 04:26 PM | #4 |
Re: Awd c10?
02-06-2014, 05:40 PM | #5 |
Re: Awd c10?
will 4x4 leaf springs and front axle bolt up to a 2wd frame
02-06-2014, 06:02 PM | #6 | |
Re: Awd c10?
"DON'T TOUCH THE TRIM!!"-Early Kyler |
02-06-2014, 06:23 PM | #7 |
Re: Awd c10?
No they won't bolt up.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
02-06-2014, 06:44 PM | #8 |
Re: Awd c10?
i think your best bet would be to take the driveline out of an AWD Safari van
1986 LWB c10 w/327 & vortec heads |
02-06-2014, 06:49 PM | #9 |
Re: Awd c10?
Off topic but what is the difference between AWD and 4WD? I know AWD is all the time, and 4WD isn't, but what is the difference when it comes to parts? How can AWD function at highway speeds when 4WD can't? Does that make 4WD somehow more powerful?
02-06-2014, 06:53 PM | #10 |
The One And Only !!!
Re: Awd c10?
Less work and $ just to go buy a driveable 4x4 truck !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-06-2014, 07:22 PM | #11 | ||
Re: Awd c10?
It is a bit more complicated than that, but it gives you the idea.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-06-2014, 07:36 PM | #12 |
Re: Awd c10?
I have never seen a square made into an AWD. I have seen on a 88+ style where someone took a 1/2 ton 4wd and made it into an AWD with Denali parts. It looked more like a lowered two wheel drive but it was AWD. Actually was pretty cool.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
02-07-2014, 10:09 AM | #13 |
Re: Awd c10?
could I use 2wd leaf spring up front with a 4wd front axle on my 2wd frame? what kind of mods would I have to do to get the front perches mounted on the front of my 2wd frame or is it even possible to do since I don't think it bolt right up? if so wat year front axle, springs or whatever would I need to do this? let me know thanks!!
02-07-2014, 10:15 AM | #14 | |
Re: Awd c10?
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-07-2014, 11:26 AM | #15 |
Re: Awd c10?
Olds Bravada Tcase uses viscous couplings. Whenever the front and rear drive shafts see spin greater than accounted for in turning, the fluidgets hot and locks them together.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
02-07-2014, 11:47 AM | #16 |
Re: Awd c10?
02-07-2014, 12:11 PM | #17 |
Re: Awd c10?
FB85C10- look in the section All 4x4 Tech & Off Roading and check for poeple doing 2x4 to 4x4 conversion . it will give you a really good idea of whats involve.
02-07-2014, 07:05 PM | #18 |
Re: Awd c10?
GM made millions of them. They called them K10's with NP 203's. There is no better system on icy roads.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-07-2014, 07:13 PM | #19 |
Re: Awd c10?
x2
65 C20 292 4spd 4:56 Eaton HO52 |
02-07-2014, 07:49 PM | #20 | ||
Re: Awd c10?
IMHO, that was the worst system ever designed. The only half-way decent ones are those that have been converted to part-time, 'cause you are still running a chain drive case. The called that mess, "full-time" 4 wheel drive, yet you could jack up any one wheel and it would spin....and the truck would not move. How is that any time 4 wheel drive? Oh, it's not. The drove "heavy" and felt cumbersome. Converting one the part-time with a kit made it feel like you gained 50 hp. If it really is icy, just lock it in and be done with it.
02-07-2014, 08:13 PM | #21 |
Re: Awd c10?
Back in 1994, I converted an 86 C20 from 2wd to 4x4. Since the 2wd front body mount brackets have most of the same rivet holes to mount to the frame as the 4x4, I lined up the brackets and used grade 8 bolts in the holes that matched and then drilled the frame to match the last couple of holes.
Once the front brackets are mounted, I measured back on the frame for the rear shackle bracket. Take your time here and measure it a few times before cutting holes if the frame for the bracket and make sure your markings are square. I didn't have a laser back then so I used some string (and some friends) to line up everything. I used a carbide tipped hole saw to cut the large hole for the shackle mount. The was slow and tedious but I didn't risk weakening the frame by using a torch on it. Several more grade 8 bolts (3/8") on the front and rear bracket to take the place of the rivets and I was ready to hang the front springs. However this was just the beginning of the project. The core support sat on the newly installed mount brackets but I had to drill the frame for the different trans mount support bracket. The hump in the floor of the cab is different between a 2wd and 4x4 so I had to cut and re-work a section of the hump. Next is cutting and re-routing the exhaust to fit around the t-case. Don't forget you will also need to either replace or shorten the rear drive shaft. There are a few other details I know I had address back then but those memories are a bit fuzzy. I enjoyed the work at time and my truck turned out pretty good and held up very well but looking back... I should have just sold the 2wd and bought a 4x4 and then build it the way I wanted it.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
02-07-2014, 08:56 PM | #22 |
Re: Awd c10?
My question would be does the OP mean AWD in the modern sense, or 4WD as is normal in these trucks.
I'm not sure about using minivan parts due to their being lighter duty. As far as the mid-late seventies full time 4WD and the NP203, it wasn't so good from the standpoint that they drank gas, ate front driveshafts (CV joints), and robbed power. We'd take the front shafts out in summer to make them last and boost mileage. There's a reason the big 3 got rid of full time 4WD and went back to part time. |
02-08-2014, 04:07 AM | #23 |
At the body shop.
Re: Awd c10?
My Dad always wanted to do a tornado front end for AWD
" That didnt make it any newer " " Dont antique the equipment " |
02-08-2014, 10:50 AM | #24 |
Re: Awd c10?
Here is an all/4 wheel drive corvette I came across. Something that you wouldnt expect to be 4 wheel drive.
http://www.tremek.com/forum/car-pict...-corvette.html |
02-08-2014, 11:23 PM | #25 | |
Re: Awd c10?
Yes.
