Old 02-06-2014, 05:25 PM   #1
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
66 C10 3.5/5in lowering questions.
I'd like to lower my 66 C10 3.5" front and 5" in the rear. Will I need to put in a drop crossmember or relocate the shocks with the amount I want to lower the truck? Was reading the LMC catalog I got today and they say you need a drop member with 4" or more of drop and relocate the rear shocks with 3" or more of drop? In the planning stages of my build right now so I want to order the right parts the first time. Also planning a 4 wheel disk conversion. Thanks
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 02-06-2014, 07:11 PM   #2
Pro Performance
Pro Performance's Avatar
Re: 66 C10 3.5/5in lowering questions.
Welcome to the forum!
If you are looking to drop your truck 3.5/5, I would suggest doing a 2.5 drop spindle and a 1" spring up front. With this combination, you will not need to relocate the upper shocks in the front. New shocks would be a good idea that are intended for a dropped truck, but you might be able to get by with the ones you have on there now if they are new.
Going to a drop spindle up front, does require the conversion to disc brakes as well. You can get a disc conversion in 6x5.5 so that it still matches the rear and allow you to use your current wheels. If you have older wheels that intended for drum brakes, they have a slightly different profile on the back. Because of that, it may require you to grind the caliper or run a spacer to allow for clearance. If using later wheels intended for disc brakes, then you should be good. The diagram below will show the difference.
In the rear, going with a 5" spring, I do suggest shock relocators. New shocks should be used that are shorter in the rear. Another good idea is a trac bar that is adjustable. I like the Porterbuilt, since it is longer and offers less side-to-side movement through the axle travel.
McGaughys Drop Parts:
http://www.azproperformance.com/McGaughys-67-72-C10/
Disc Brake Conversion (Includes Spindle):
http://www.azproperformance.com/Pro1...60-72-C10.html
Adjustable Trac Bar:
http://www.azproperformance.com/63-7...c-Bar-Kit.html
Pro Performance is offline   Reply With Quote
Old 02-07-2014, 07:03 AM   #3
Mikes66ChevyC10
Thank you for the info and the links!!
Old 02-07-2014, 09:29 AM   #4
DjS71
Seriously, that was a perfect informative answer without a glaring advertisement for your shop at all (aside from the links, which is what someone without a shop would have done anyway). Bravo.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
