Old 02-06-2014, 10:50 PM   #1
kedmunds
295/50/15's on Back... 235/60/15's or 245/60/15's on the Front?
OK, I just bought this 72 Cheyenne Super that has 15x8 fronts and 15x10 backs, What are your suggestions for Front and Back tire sizes if I want to go with the BF Goodrich Radial TA's?
I was thinking that because of the 15x10's wheels on the back, that I would go with the 295/50/15's. As for the front tires, I am not sure if I should go with the 235/60's with a bit of a stagger or the 245/60's that are the exact same height as the 295/50's.
Any thoughts or suggestions would be greatly appreciated before I start spending the money for the new tires.
Thank You for any suggestions or pictures that you are willing to share.
Kirk
kedmunds is offline   Reply With Quote
Old 02-06-2014, 11:00 PM   #2
cpetersen
cpetersen's Avatar
Re: 295/50/15's on Back... 235/60/15's or 245/60/15's on the Front?
They will look goofy if you use those. I have 295/50/15's in the back and 265/50/15 in the front. They are terribly hard to find.
cpetersen is offline   Reply With Quote
Old 02-06-2014, 11:05 PM   #3
cpetersen
cpetersen's Avatar
Old 02-06-2014, 11:12 PM   #4
kedmunds
I appreciate your input. Why would you say it would look goofy? I have heard many others state that they would use 235 or 245's on the front. Would it look goofy because of the height or because of the width?
I'm wondering if I am hurting myself by trying to stay with the BFG Radial TA's? I just want to get the best tires for my 15x8 Fronts and 15x10 Backs.
Old 02-06-2014, 11:12 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
I would recommend going with the 235's. What I have run into over many different staggered set-ups over the years is that if your front and rear tire are the same height, you can easily end up with the front tire being slightly taller (when mounted) if the front rim a size too narrow for the tire or the rear rim is a bit too wide.
In other words, if you put the 295's on a 10" rim and put the 245's on a 8" rim, there is a chance the front tire would install a little taller. You may put the same 245 tire on a 8.5" or 9" rim on the front, and it may be fine.
I ran into this on my shop truck. I put 275/60's on a 8" rim and a 235/70 on a factory 5.5" rim on the front. Both tires are supposed to be 28" tall, but the front were noticeably taller on the narrow rims. Luckily my front tires were already on the truck, so when I bought new tires for the front, I went with 215/70's and it looked good then.
If you go with a front that is slightly shorter, you usually don;t have to worry about that happening.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-06-2014, 11:16 PM   #6
67_C-30
67_C-30's Avatar
FWIW, I would go with 275/60 and 245/60 with your wheels and it would look pretty good. The 26.6" tall 295's look short on a truck. The 28" tall 275's with stretch out to around 27.5" on the 10" and will look better, IMO.
This was one of my trucks with 255/60 and 275/60 BFG's , but I only had a 8" rear rim, which made the 255/60 - 275/60 pretty close to the same height.
My trucks
Old 02-06-2014, 11:17 PM   #7
kedmunds
Thanks for the information. I am currently leaning towards the 235/60 fronts because they will be just a bit shorter than the backs. I really cannot stand it when my front tires are taller than my backs.
So far, the 295/50's and 235/60's are winning.
BTW, here is the pic of it with the Mickey Thompson ET Streets on the back and Nitto's on the front.
Kirk
Old 02-06-2014, 11:21 PM   #8
67_C-30
67_C-30's Avatar
BFG's are great tires. You just need to know what OD you want.
A 265/50 is actually shorter than a 235/60 and even moreso than the 245/60, but they are much wider...
My trucks
Old 02-06-2014, 11:23 PM   #9
67_C-30
67_C-30's Avatar
Kirk
That is a slick looking truck! It will look much better with a shorter rear tire, IMO. What size is the current front tire on there?
My trucks
Old 02-06-2014, 11:37 PM   #10
cpetersen
cpetersen's Avatar
I can't find my stinkin flash drive with my other pictures after I lowered the truck. I love the 15" wheels because they actually have some sidewall. But you can't get 50 series tires anymore, next set of rims will be 18". 265/50/15's fit the best they are 1.5" shorter and fit on a 8.5" rim real well. I got lucky and found one pair of cobra coopers for them. BFG used to make them too, they only make a drag tire in that size now.
Old 02-06-2014, 11:43 PM   #11
67stepper
67stepper's Avatar
Im running 255/60/15 in front and 275/60/15 in back,
but all four of my wheels are 15x8.5
lowered 5 in in back and 2.5 in front.
zero rubbing
sorry couldnt get my pic to post.
67stepper is offline   Reply With Quote
Old 02-06-2014, 11:47 PM   #12
kedmunds
Someone else told me that I should run 275/60's on the back, but I wasn't sure how that would work on the 15x10 wheel? I thought it would be more stretched than I would prefer. Thoughts?
Old 02-06-2014, 11:49 PM   #13
cpetersen
cpetersen's Avatar
I think the max you can run is a 9.5" width. Go on to tirerack and you can get the specs.
Old 02-06-2014, 11:56 PM   #14
67stepper
67stepper's Avatar
got it
Old 02-06-2014, 11:56 PM   #15
cpetersen
cpetersen's Avatar
Looks like Hankook is making a 265/50/15.
Old 02-06-2014, 11:58 PM   #16
C/10 King
C/10 King's Avatar
Call me goofy!!! I am running a 245/60/15 and 295/50/15 combo with a 3/5 drop with some 8.5/10 wheels and I think it looks okay.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 02-07-2014, 12:02 AM   #17
kedmunds
That setup looks Amazing... Now I am leaning towards the 295/50 and 245/60 setup. That looks great. My question to you is are you happy with both the front and back tires being the same height? How does it look from the side and are they actually the same height between the front and back?
Old 02-07-2014, 12:09 AM   #18
67_C-30
67_C-30's Avatar
Just keep in mind that the 8.5" rim is going to make the 245/60 slighty shorter than they will on a 8", although it may be OK either way. If Rene's (C/10 King) fronts are a slightly shorter on the 8.5's, you should be fine with the 245's on the 8" rim.
My trucks
Old 02-07-2014, 12:13 AM   #19
Molberg
Molberg's Avatar
I have 245/60/15 on front... And 295/50/15 on rear. It doesn't look goofy! Its just math. Gives you the same overall height. 295/50/15 being 29.5 cm across tread... The "50" being the sidewall height as 50% of the 29.5 tread width. If you want the same overall wheel height with 295 on rear... Go with 245/60/15 on the front. Do the math. It works out to the same overall wheel height. If you're looking for a bit of "rake" to your stance.. Adjust accordingly. I have 8" rims front and rear. Yes... Different rim widths will mess with sidewall height.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-07-2014, 12:17 AM   #20
C/10 King
C/10 King's Avatar
I never put them next to each other, since BFG no longer made 265/50/15 I just choose 245/60's because I always thought 235's were too small and with the 3/5 stance I thought these sizes were prefect, and I never looked back.
C/10 Rene
1971 Short Fleet
Old 02-07-2014, 12:17 AM   #21
kelsfine69
18 Till I Die
kelsfine69's Avatar
I have 295/50 on the back and 235/60 on the front and the 60's were tough to get on the 8" rallys but did go on. I was thinking of going with a 245 on the front to just get a bit bigger to fill the wheel well on a stock height truck. I think with the same tires all the way around the stock height trucks have a slight rake to them built in. M2c
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-07-2014, 12:52 PM   #22
cpetersen
cpetersen's Avatar
I finally got a side pic so you can see the sidewalls. It all depends on taste, and some what where you drive. I live in Phoenix and the roads are pretty nice here. I couldn't drive this truck in lets say Albq or Denver, it would beat the truck to death you would have to have more sidewall. I'm running 265/50/15 in the front over a 8.5" wheel. I like a little rake with the sidewall. I'm cringing about buying new rims, I suppose I will go with 18"s I just don't want to see rims with rubberbands on them. Call me old school, I still like the way 15's look the best the offsets and backspaces still look the best, but the tire selection for the wide rims isn't very good. Good luck with your choice.
Old 02-07-2014, 01:47 PM   #23
dmartin1
dmartin1's Avatar
its on my 78 shortbed, but i have 295/50/15 on a 10" wide on the rear and 245/60/15 on the front and abseloutly love it it fills it just enough and looks really good.
i think the 295 and 245 is a good combo
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
