Old 02-07-2014, 01:36 AM   #1
68chevystepside
68chevystepside's Avatar
Exclamation ? about ECE front end rebuild kit...
I am planning to purchase the front end rebuild kit from ece. my 68 originally came without power steering but i plan to have power steering in it once i can figure out what p/s hoses/lines i will need from the gearbox to the pump with the 89 g30 350 engine that's in my truck. so the question is can i use the p/s front end rebuild kit or do i have to get the non p/s front end rebuild kit?
also is there anyone u guys recommend from ece to contact when i make my purchase or is there someone from ece on the forum that i can contact?
68chevystepside is offline   Reply With Quote
Old 02-07-2014, 07:53 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: ? about ECE front end rebuild kit...
You want the PS kit. The difference between the two is the pitman arm. Power and non power pitmans are different.
Figuring out the power steering lines is no problem at all. When you get to that point, come back here and we can lead you right through it.
Old 02-07-2014, 10:18 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Stan can help you there. Just give him a call. He will knowthe answers and you can trust them.
Tom Vogel is offline   Reply With Quote
ece
