Old 02-07-2014, 09:26 AM   #1
72chevylwbmo
Axle swap, will it fit?
I have a 72 lwb chevy with leaf springs. I had a friend of mine give me a 12 bolt axle out of a 95 truck. It has 3:73 gears in it that he claims are brand new. I was wondering if that axle would bolt right under my truck? Also could I put the spring perches on the bottom to lower the rear end of my truck?
72chevylwbmo is offline   Reply With Quote
Old 02-07-2014, 05:12 PM   #2
motorcritter
motorcritter's Avatar
Re: Axle swap, will it fit?
Measure it! With a welder and cutting rig, and the right brackets, you could install just about anything- that fits!
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 02-07-2014, 05:55 PM   #3
Fitz
And you can narrow the housing with those same tools!
Fitz is offline   Reply With Quote
Old 02-07-2014, 06:28 PM   #4
mrolds88
Also do a double check on that. Never seen a stock 12 bolt in something that late model.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-07-2014, 07:23 PM   #5
Molberg
Molberg's Avatar
.....lol. And the axles?
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-08-2014, 09:43 AM   #6
72chevylwbmo
Thanks guys. I am hoping that it will just bolt right up. I am also hoping that I can just swap out the axle shafts because the 95 axles are 6 bolt.
Old 02-08-2014, 10:59 AM   #7
Bigdav160
Bigdav160's Avatar
Pretty sure that is a negative
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-12-2014, 10:05 AM   #8
72chevylwbmo
Well, last night I had time to look at the axle that was given to me. It is not a 12 bolt, it is a 10 bolt axle. He is still stating that it has brand new 3:73 gears in it. I have a question though, what should have came out stock in our trucks to begin with. I'm not sure I will be ahead any by installing this axle in my truck, except maybe the gears. Hopefully somebody can enlighten me.
Old 02-12-2014, 12:49 PM   #9
zeldman
zeldman's Avatar
I am guessing that the 72 came with fuel saving 3:08 gears. If you have the cover off the 95 rear, get the numbers off the ring gear for the ratio.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 02-12-2014, 06:32 PM   #10
Fitz
torch em!
Old 02-12-2014, 09:18 PM   #11
hugger6933
The 95 rear with 6 lugs would be a 8.5 inch rear that should have come from a 4x4 truck and quite a few of those had the Z71 option and that added the posi to the rear end. Depending upon what the motor was that your truck came with from the General that would make a difference on the rear gearing. Jim
hugger6933 is offline   Reply With Quote
Old 02-13-2014, 02:04 PM   #12
72chevylwbmo
Thank you Jim, that is what I am trying to figure out. Is the 95 axle stronger than what came in the 72. When I get time off from the rent house I am going to look into this more.
