02-07-2014, 12:44 PM | #1 |
Extra Bolster for Buddy Buckets
Hey doods. I've been rollin a set of tattered 67-68 buddy buckets in my 64 for a few months and it's (well beyond) time to recover them.
I'd like to add some bolstering to the seat bottom and back when I replace the covers. I've been considering two options:
For option 2 I have been looking at these Chevelle Sport foams. Has anyone done or seen anything similar? |
02-07-2014, 11:10 PM | #2 |
Re: Extra Bolster for Buddy Buckets
No one huh? I guess I'll have to pioneer it!
02-08-2014, 07:27 AM | #3 |
frizzle if you ask me the dodge seats have more of a bolster than the chevys.
the first set has a differnt shape than the second but these are both built on the same frames as the chevy seats...both of these were a $20. jy score
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
02-08-2014, 09:57 AM | #4 |
Any real auto trim upholstery shop can easily shape your seats any way you want them also build you any type custom covers, add embroidery or anything else your heart desires as far as you want to go from MILD TO WILD ! Forming custom bolsters requires the correct foam and Glue and NO you can't use spray can glue and expect it to last .They will build new foam using your current foam in your seats as the base ,DON'T BUY NEW FOAM YOU DON'T NEED IT !!!
Try Scotties auto upholstery 326 sw dennis ave IN YOUR HOME TOWN .504-640-8733 |
02-08-2014, 11:44 AM | #5 |
Frizzle Fry, I had these seats tucked. The way they are tucked and padded make these seats extremely comfortable. I sold these to Jeh ( Jason ) on the forum last year.
Here is the link for the ad, it has a couple more pictures in it http://67-72chevytrucks.com/vboard/s...d.php?t=565657
Scott Last edited by sduckworth13; 02-08-2014 at 11:56 AM. |
02-08-2014, 11:46 AM | #6 |
One more of picture of the vinyls.
Scott |
02-08-2014, 11:51 AM | #7 |
I'd also recommend new seat bottoms because the old cushions disintegrate and make a nice big mess under the seat.
Scott |
02-08-2014, 11:53 AM | #8 | ||
BTW, I've used Scotties in the past and they do good work. |
02-08-2014, 11:56 AM | #9 |
02-08-2014, 11:59 AM | #10 |
The extra cushion around the outside of the seat top and bottom.
Scott |
02-08-2014, 12:01 PM | #11 |
Adding the insert in the middle of the seat allowed me to have them tucked and not make the extra foam look like a oversize recliner like some seats do
Scott |
02-08-2014, 12:55 PM | #12 |
You can't increase the size of the bolster without increasing the size of the covers , so you would have to have custom seat covers made to change anything other than the stock look ,You can't shove 10 pounds of foam into a 5 lb bag , Believe me I have been self employed building custom interiors for 35 years , I just did a set of buddy buckets for my neighbor with repairing all the foam and custom made covers using Allante simulated leather and he paid $400.00 so you should be able to get what you want for less than $600.00 and have them professionally done , The foam in buddy buckets encapsulates the frame work your not just going to pull off the covers and lift out the foam and drop in new foam , it rarely has to be replaced and is easily added to to get the look you desire ,all it takes is a phone call you may be surprised at the cost ? If you were closer I'd build them for you Cheap ! i will walk next door and get a picture of his reupholstered seats and post it shortly .
02-08-2014, 01:11 PM | #13 |
just picked these up the other day, had the upholstery shop add some more foam to them, black leather with red stitching
02-08-2014, 01:31 PM | #14 |
Here are a few pictures of the seats I recovered for my neighbor , and I have to thank you for your posting because While I was there he showed me 2 more sets he found and I traded him a set in exchange for reupholstering the second set he had extra , So score one for Grumpy ! He also just bought the blue '68 short bed and it has buckets in it that I will soon recover for him .
http://http://http://http://http://http:// |
02-08-2014, 01:42 PM | #15 |
02-08-2014, 01:51 PM | #16 |
As mentioned,if you change the cushions the original covers won't work. I plan custom upholstery,so will make cushions to fit that plan.Depending on cost,I'll either modify (add foam/shape) or just go with custom cushions all the way. The design I have in mind isn't all that different from the '68 style,with bolster around outer edges. I'll cross that bridge when I get there.Prolly run as is,like you,for a long time
02-08-2014, 03:34 PM | #17 |
Grumpy, you do some outstanding work. Your seats look awesome!
Scott |
02-08-2014, 05:41 PM | #18 |
Thanks , I'm just trying to let some guy's see that you can have anything you want interior wise just like paint or engines , Everything doesn't have to come out of a box with china stamped on it on a ups truck .
02-08-2014, 07:59 PM | #19 | |
Thanks |
02-08-2014, 08:23 PM | #20 | |
Hey Friz,great avatar!
About the same years as these GM trucks...but probably more than 67/68. Dodge ran the same body 61-71,but the seats I'm sure didn't run from start to finish.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-08-2014 at 08:58 PM. |
02-08-2014, 09:03 PM | #21 |
Thanks S.K. I've had it for a long time, but haven't been active on this part of the board for about the same amount of time
Good stuff guys! Thanks for the inspiration. Grumpy, you rock That is some solid work you do. Can you offer any details about the foam and glue you use to repair existing foam? I've been looking at PUI Interiors stuff which is all made in the US. Last edited by Frizzle Fry; 02-08-2014 at 09:10 PM. |
02-08-2014, 09:13 PM | #22 |
02-08-2014, 10:07 PM | #23 |
any foam and fabric store will have many different densities of foam in block form , just buy a 3'' thick firm block say maybe 4'x4' should cost less than $15.00 to cut it to size you can buy any electric carving knife from walmart for $8.00 to rough it out then use a 90 degree angle grinder and a roloc scotch brite 2inch pad to fine tune your bolsters , you want to use a commercial grade contact cement (glue ) ace hardware sells it in quarts /gallons it's called weldwood contact adhesive and you want to use the landau top grade about $30.00 a gallon you don't need more than a quart at the very most (vinyl top ) grade you can spray it thru any cheap /harbor freight spray gun at 75-90 psi /Or brush it on .If you can't find that any home depot CONTACT grade laminate(counter top ) adhesive will work as long as you allow flash time before attaching pieces . once your happy with your bolsters spray each side of the ajoining foam and WAIT 3-5 MINUTES then set in place and once attached you can fine tune them using the angle grinder , make them all match and take it to Scottie's and let him cover them ! Ask about Allante vinyl looks like leather ,feels like leather, never cracks /fades/or shrinks And if he wants to charge too much send them to me and I will reupholster them for the cost of materials and shipping !I'm retired I already made my money !
02-08-2014, 10:33 PM | #24 |
02-08-2014, 11:22 PM | #25 |
Will the seat covers from the Chevy seats fit on the dodge seats?
