Old 02-07-2014, 01:08 PM   #1
mothertruckr
mothertruckr's Avatar
wiper motor wiring help for 79 c10
Anyone have a diagram of what each terminal does for a wiper motor?
Re-wiring the truck, and i am having trouble with this
07 GMC Sierra NNBS ccsb 4wd 6.0L
98 ram 2500 cummins 2wd 6spd 360rwhp 800ftlbs f/s
1979 C10 383 stroker turbo 400 sold
mothertruckr is offline   Reply With Quote
Old 02-07-2014, 01:33 PM   #2
ray_mcavoy
Re: wiper motor wiring help for 79 c10
Thanks to hatzie, you can download a factory wiring diagram here --> http://67-72chevytrucks.com/vboard/s...d.php?t=545416
The 78-up wiper motors have 3 connectors:
(1) The 3-terminal connector near the lower end of the motor has a +12V feed and two switched ground connections that are wired back to the switch. The switch is on the ground side of the circuit.
(2) The 2-terminal connector up near the top is for the parking switch. That is responsible for returning the blades back to the parked position at the base of the windshield when the dash switch is turned off.
(3) The other 2-terminal connector with the larger wide blades out on the front is for the washer pump solenoid. One of those terminals is +12V feed and the other is a switched ground. Again, the wiper switch is on the ground side of this circuit.
ray_mcavoy is offline   Reply With Quote
