Old 02-07-2014, 01:32 PM   #1
poov71
poov71's Avatar
Front shocks for the lowered?
Forgive me..I could have posted this in the suspension section but was afraid it would be over looked. My truck is lowered about 4 or 5 inches in the front. I have destroyed two sets of shocks in less than 1000 miles. What are your experiences/recommendations when it comes to front shocks for lowered trucks? I did not use shocks specifically for lowered suspensions. Is this the problem?
poov71 is offline   Reply With Quote
Old 02-07-2014, 01:42 PM   #2
whitedog76
Re: Front shocks for the lowered?
You're probably bottoming out your shocks.
Try this site out.
http://www.monroe.com/assets/downloa...engthSheet.pdf
If you know what part number of the oem shock is, you can go here and find a shorter one.
You could also modify your control arms by welding a tube to the lower or upper and a plate to bolt on to.
whitedog76 is offline   Reply With Quote
Old 02-07-2014, 06:30 PM   #3
LONGHAIR
It depends upon the lowering method.
Lowering with spindles has no effect on shock length. Lowering with drop coils or by cutting the springs, does require a shorter shock or movement of the upper mount to accommodate them. The lower bump-stop must hit before the shock is fully compressed.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
