02-07-2014, 03:18 PM | #1 |
Stock front shock mounts. Are they cast?
I moved the upper mounts, and would like to match the angle with the lower mounts. I'd like to just heat them up and bend them a bit, but I'm not sure if I can because I think they might be cast. Anyone know?
02-07-2014, 04:27 PM | #2 |
Re: Stock front shock mounts. Are they cast?
I'm pretty sure, they'r just stamped steel. If nothing else, you can make your own.
Why did you move the shocks? Did you stand them up to work better? |
02-07-2014, 04:45 PM | #3 |
Hollister Road Co.
The uppers are stamped steel the lowers are cast iron.
02-07-2014, 04:54 PM | #4 |
Thanks. Looks like I'll be making some. Ya, I stood them up closer to vertical.
02-07-2014, 06:20 PM | #5 |
That's good to know. I'm thinking of the same thing.
I've been doing some research, seems as though the shocks at their present position is only about 85% effective. Standing them up makes more sense. |
02-07-2014, 06:47 PM | #6 |
Ya, the stock position is roughly 45 degrees, kinda seems pointless. I've got mine at 15 degrees.
02-08-2014, 12:22 PM | #7 |
did you use a shorter shock ?
02-08-2014, 12:44 PM | #8 |
Hollister Road Co.
I was always under the impression that 22 degrees was the max allowable tilt on a shock.
02-08-2014, 12:54 PM | #9 |
I'm thinking that they are cast steel rath'er than cast iron. It wouldn't be hard to fab a pair out of steel plate and set the angle you wanted.
You might even change top and bottom brackets to use shocks that have an eye or stud . to get a more upright angle like the ford F1 trucks run.
02-08-2014, 01:21 PM | #10 |
Ya, I've got shorter shocks.
The majority of the info I read was saying somewhere around 30 degrees was the max you want to set them at. I figure I can fab something up with some 3/16" plate. |
