Old 02-07-2014, 04:49 PM   #1
Rc4mike
My axle centerline
I installed my mustang ii front end. Axle is 1.75" forward of original. This is at ride height w 18" wheels. I think this is good. Thoughts?
Rc4mike is offline   Reply With Quote
Old 02-07-2014, 04:53 PM   #2
Red Foreman
Red Foreman's Avatar
Re: My axle centerline
Yep you done well looks good.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 02-07-2014, 05:00 PM   #3
Fatherof3
Fatherof3's Avatar
Needs more low
Are the new gen Camaro wheels just for mock up?
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 02-07-2014, 05:17 PM   #4
Rc4mike
Originally Posted by Fatherof3 View Post
Needs more low
Yes it does need to go lower. These are stock spindles but might get dropped spindles...arguing w my teenage son on this. He wants it taller!
Yes the camaro wheels are for mockup...good eye.
Old 02-07-2014, 06:03 PM   #5
Fatherof3
Fatherof3's Avatar
Is the truck for him?
Old 02-07-2014, 06:04 PM   #6
Rc4mike
Good point..hell no. It's all mine.
Old 02-09-2014, 12:04 AM   #7
_Ogre
_Ogre's Avatar
wait until you have your truck all together before you think about drop spindles.
i have a mustII on my truk, it looked too high until i bolted everything in/on it.
not sure mine would be streetable with drop spindles on it.
doors, glass, interior, hood; everything you bolt on will drop the truck a little until it looks similar to this
shop air compressor timer
Old 02-09-2014, 03:07 PM   #8
Rc4mike
Good point. I like your stance. Is your frame level at ride height? I'm about to start the rear end so need to set rear height.
Old 02-09-2014, 03:21 PM   #9
Highsider
Highsider's Avatar
_Ogre knows what's up.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 02-09-2014, 03:51 PM   #10
hotrod1
56 - autocross
hotrod1's Avatar
Ogre: That is one good looking truck!
hotrod1 is offline   Reply With Quote
Old 02-10-2014, 02:10 AM   #11
The805Garage
The805Garage's Avatar
Newbie! so can someone school me or direct me to a thread on why the front centerline needs to be moved forward when installing a mustang II style front end? much appreciated!
The805Garage is offline   Reply With Quote
Old 02-10-2014, 09:18 AM   #12
Rc4mike
I don't think its limited
To mustang II suspensions. I've seen camaro clips also moved forward.
W larger wheels, the stock location does not look centered in wheel well esp when u lower the truck
Old 02-10-2014, 11:57 AM   #13
ZR2RICK
ZR2RICK's Avatar
as someone has said, you need all the weight on it with the final tire/wheel choice and at final ride height to properly determine if the wheel will look centered, as the suspension compresses there is a slight rearward arc (more or less depending on type of suspension)
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 02-10-2014, 12:04 PM   #14
MARTINSR
MARTINSR's Avatar
Or of course if you know what the final height will be you can pull the suspension down with all thread in the shock location. I have done that before. So the truck could be brought outside to check it out. This is something so many people miss, roll it outside and take a look after a mod so you get a good look at it.
In this photo I have no engine in it. I used all thread to replace the shocks and pull it down where I wanted it. The rear is too high because I didn't do that but only removed the wheels and had the frame on shortened jack stands at the height I was going to have.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-10-2014, 04:08 PM   #15
mr48chev
mr48chev's Avatar
If you don't have it fastened in yet I think I'd slip it back 1/2 towards the rear and take some more photos.
I agree with Ogre on waiting buying or installing dropped spindles. It may be money you don't have to spend and it only takes a couple of hours max to swap both spindles if you do decide to go to dropped spindles.
Brian showed what getting it right is all about in his photo of his truck. Those wheels are perfectly centered front and rear and really add to the looks of the truck in the process.
My ongoing truck projects:
Old 02-10-2014, 04:16 PM   #16
Rc4mike
I did after that photo and now looks much better.
Old 02-10-2014, 06:08 PM   #17
Speedbumpauto
Speedbumpauto's Avatar
Alright X2! I didn't want to be the one that said it.
Speedbumpauto is offline   Reply With Quote
Old 02-10-2014, 07:23 PM   #18
_Ogre
_Ogre's Avatar
ride height is static; what you see is what you get
the a-arms on your mustII ifs should be level when your fully loaded
plus they will drop a bit after a year of flexing the springs
truk rides on stock (rebuilt) springs out back, minus the 2 short overload leaves and flipped on top of the springs.
read my build, i have it all pretty well documented in the build thread.
when i mocked up my front end i believe i moved my axle 7/8''
Old 02-10-2014, 07:30 PM   #19
Highsider
Highsider's Avatar
Me too.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
