well after a string of bad luck, from breaking the rear first time at the track and running a dissapointing 13.2, then fixing the rear only to find out when i started it up it was knocking, broken crankshaft, im finally where i should be. best pass was a 12.71, best mph was 106. all throttle no bottle. man it took a while but im finally happy, now to start tuning and hopefully not break anything else.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
Congratulations!
That must be fun. Jim Last edited by JimKshortstep4x4; 07-22-2003 at 01:09 PM. |
Pick'n up the pieces!
pics?!!! Congrats!
man thats smokin....
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
That's fast as hell.
.....into the 12's with a small block and no bottle...very nice work
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
THE QUICKER FIXERUPER
running a dissapointing 13.2. I would be happy to run a 13.2
if you and the truck weigh 3800lbs your HP is just over 550...you got to tell me your secrets
Formerly yellow72custom
Your hauling....i would be happy if mine ran high 14's, lol.
What are the specs on you engine and drivetrain?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Thanks for all the replies, truck is a 68 short fleet, weighs 3575 with me in it, small block 406 with 12:1 compression, dart iron eagle heads with 2.05 valves, lunati solid lifter cam with 1.6 roller rockers which makes the cam have 585 lift. victor jr intake and a 750 dp., mallory unilite, hooker super comps, csi water pump. centerforce clutch, muncie car m-20 four speed, , 12 bolt truck rear with 4:56 richmond gears and moser axles. mickey thompson 30x12.50-15 et streets. i will send pics in when i get home (im at work now
Good times! What did you do to get it that light? My truck weigh's right at 3900lbs with me in it. What was your 1/8 mile time and MPH?
Your UncleBen
![]() Join Date: Dec 2002
Sweet running man! I would say with that 406 and your light weight 12s is pretty good! I am sure that 406 is putting down some NICEEEEEE HP.
have fun with it. lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
#13 |
1/8 mile times were 8.1-8.2 at 85-86 mph. truck is stripped of anything that i could, no tailgate, rear bumper, heater, radio, inner fenders etc., has plastic seats, aluminum wheels, etc, the rest just rusted away. lol. i will try to post pics. Dev.
#14 |
motor
#15 |
again
#16 |
oops
#17 |
still loaded up from the drive home from the track.
#18 |
wow these pics are pretty bad.
#19 |
man...that's awesome times on motor alone....who says trucks can't be fast!
