Old 02-07-2014, 10:46 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink Transmission senor
OK so the tune is done. I need to know if I can get the transmission temperature reading from the 4l80e wiring are not. I would like to have it on the Scan gauge if possible. I have the code for it entered and the gauge set but it has no reading. This is for a 2003 2500HD 6.0.
According to Scan Gauge they swapped codes for everything in 2003.
I have tried both sets of codes but no good.
Bruce said without a Vin number for the vehicle there is noway to know.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-07-2014, 11:04 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Transmission senor
I found this info.
http://www.rostratransmission.com/manuals/Form4157C.pdf
Old 02-08-2014, 01:37 AM   #3
truckdude239
truckdude239's Avatar
Trans should have a sensor in it already.
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-08-2014, 04:07 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm not positive how it works. I know it can throw over-temp codes, and HPT can read the info.
We've installed a trans temp gauge before on a diesel truck with the 80e....there are unused bungs on the side of the case which are for testing pressure or something. You can use the 1/8" hole to connect the sender for Autometer-type gauges.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-08-2014, 07:39 AM   #5
Andy4639
Old member
Andy4639's Avatar
Yes I have read there is a test port right above the gear selector on drivers side. I have also herd that the transmission should have the temp senor in it. Bruce said he was going to findout more for me but I was wanting to see if I could find anything. I figured the experts here would know more about it. I'm going to go by the transmission shop one day next week and findout what they have to say about it.
I found this too!
http://www.trucktransdiag.com/downlo...-tech-info.pdf
From what I have found this morning googling it should have a senor in it. I have to figure out how to get the info now and if it was turned off when they did the wiring and reflash.
Old 02-08-2014, 11:24 AM   #6
Hart_Rod
Hart_Rod's Avatar
I looked in the tune for a 2500 HD with a 4L80 but didn't see anything that addressed the temp in the tranny. I know my 6L80 has all those features and I can see the temp on my DD VHX gauges as well as my scanner. If you guys figure something out, let me know and I will check again.
Edit: Ask Clinbarger, he's the resident tranny expert!
Hart_Rod is offline   Reply With Quote
Old 02-08-2014, 01:35 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
My Aeroforce Interceptor will display trans temp.
Only "sensors" on my 4L85e are the 2 VSS?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-08-2014, 02:12 PM   #8
ls1nova71
ls1nova71's Avatar
Have you tried another year? I don't think your engine is an 03. Try 01 and see what happens? Some 2500 and up trucks have a trans temp guage so the trans may have the sensor already, but its most likely a serial data gauge, but I would think a Scangauge should read it if its there.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-08-2014, 05:13 PM   #9
68GMCCustom
both my '68 with it's '09 LY6 w/4L85e... and my TBSS with '06 LS2 w/4L70e... I've been able to just plug in, set it, and pull trans temp from the diagnostic port, w/o adding/changing anything to either system.
Kurt -
Old 02-08-2014, 05:46 PM   #10
68c10airstream
68c10airstream's Avatar
Hi Andy, just looked up your info request on a 2003 2500hd 6.0 on alldata pro version and the trans temp thermistor info goes to pcm and is available at the instrument cluster through the class2 serial data. This serial data carries other info, volt gauge info, etc. Your posted link info showed the 2 wires related to trans temp info on a 5 volt reference line to pcm. The pcm analizes all the info needed and sends it out on serial data line. I always compared the serial data line to a phone line, transmitter, receiver and more than one person on-line processing the info. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 02-09-2014, 02:21 AM   #11
clinebarger
On later 4L80E's the Temp Sensor is integrated into the internal harness.
Even if the sensor/wiring had an Open circuit it would read "Low" around -40. If the sensor/wiring had a Short it would read "High" around 300 degrees.
First thing I would do is hook-up a real scan tool a see what the Trans Temp reads.
Circuit Diagnostics....
Unplug the Trans connector, Key on, Check for 5 volt reference on Pin L, Check for Ground on Pin M. This will check the harness side. See Connector View.
On the Trans side, Check Resistance between Pins L & M, See resistance chart.
clinebarger is offline   Reply With Quote
Old 02-09-2014, 07:06 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: Transmission senor
Thanks guy's. Sorry I been out of town since early yesterday for a wedding. No computer time. Just got back. Will check tomorrow on the scanner tool.
I sure hope I can figure it out. It would be nice knowing trans temp.
