Old 02-07-2014, 11:16 PM   #1
69 4by
Clutch problems!!!
Hi, I just had the clutch on my 69 rebuilt,I put it back in and now cant get the transmission to get in gear. The clutch seems to work fine and the trans shifts when not running but when the truck is running it just grinds. Just wondering if anyone knows what it might be or has had these problems. THANKS
69 4by is offline   Reply With Quote
Old 02-07-2014, 11:27 PM   #2
kev0519
Re: Clutch problems!!!
i put a clutch disc backwards wouldnt disengage {trans wouldnt go in gear because input shaft on trans still turning while running}
kev0519 is offline   Reply With Quote
Old 02-07-2014, 11:38 PM   #3
imjeff
imjeff's Avatar
It's either waaaay out of adjustment or the disc is backwards or the throw out bearing isn't on the fork correctly or? I'm betting the disc is backwards. When it's not running you don't need a clutch. For that matter you don't need one except to start and stop. Whatever the cause, the clutch is not disengaging.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-07-2014, 11:58 PM   #4
69 4by
Thanks guys, Knowing me I probably put the disk on backwards. I guess i have something to do again!
