02-08-2014, 05:54 AM | #1 |
Will these fit? Universal 'vette master cylinders
Will the universal 'vette mc's fit on the '71-'72 c10's? They look pretty much identical when using the outlets on the driver's side--many have outlets on both sides with plugs to cap off the side you do not use. Also, these universals seem to come in 2 flavors--'67-'76 and '77-'82.
I like the looks of the fat reservoirs and would want to use the ones with 1 1/8" bore, as my ride has power with disc/drum setup. I'm also using the '71 m/c having the 1 1/8" bore now, along with its matching dist'n block/prop. valve. My pedal has started creeping down while stopped like at a light, so I know it's time to replace the m/c. Thanks, Sam |
02-08-2014, 07:42 PM | #2 |
Re: Will these fit? Universal 'vette master cylinders
Yes they will work with no issue, used one on my 68. Get 1" bore if you want firmer pedal.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
02-09-2014, 09:31 AM | #3 |
As 71super said, they work great. I have one on my 67 C10 disk/disk and on my 72 Vega Wagon disk/disk. I used an adjustable prop valve on each.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
02-09-2014, 10:24 AM | #4 |
Just did this, just also pay attention to deep vs shallow bore also.
