Old 02-08-2014, 02:22 PM   #1
53lowdown
Junior Member
53lowdown's Avatar
Heater Control
I'm trying to figure out my 62 C10 heater controls for thrift heater. I only have two levers on the control. One for the fan switch, and one that pulls the cable to the heat/defrost flip door.
Doesn't there have to be a third lever for the valve to shut off the coolant circulation?
The control doesn't look like it has been hacked up, but there are only two levers.
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 02-08-2014, 02:40 PM   #2
forestb
forestb's Avatar
Re: Heater Control
I don't think there is one.
forestb is offline   Reply With Quote
Old 02-08-2014, 02:58 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Heater Control
I just went through the 1960 Recirculating Heater installation instructions and there was no shut off for the hot water. They didn't even suggest a mechanical valve on the hoses, just straight hook up from the engine to the heater. Must have been pretty uncomfortable in warm climates.
Here are the pages from the factory accessory manual:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-08-2014, 04:32 PM   #4
53lowdown
Junior Member
53lowdown's Avatar
Re: Heater Control
Good info - thanks. Not much concern about too much heat right now! I guess in the summer I could just put a short loop of heater hose to bypass the heat exchanger.
