02-08-2014, 07:51 PM | #1 |
Disc Brake kits 8 lugs
What kits are you guys using ?? For 8 lug disc brakes
1969 C20 CUSTOM "RUMBLEr" |
02-08-2014, 08:19 PM | #2 |
Re: Disc Brake kits 8 lugs
I'm curious about this also (for the rear axle 4x4)
02-08-2014, 08:57 PM | #3 |
Front is a straight bolt on of factory parts up through 91 in some cases.
http://67-72chevytrucks.com/vboard/s...68&postcount=4 Rear discs are more of a problem. If you find a C20/30 kit with a real park brake and not a car rated caliper let me know.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 02-08-2014 at 09:04 PM. |
02-08-2014, 09:20 PM | #4 |
Roto Reuter thats the name...
Only did fronts on my C20. I researched both CPP and POL I decided to use Performance Online.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-08-2014, 09:22 PM | #5 |
If you are speaking of front disc brakes, i have a complete swap out from a 71 3/4 ton that would do the job for ya..and I am local to you...
02-08-2014, 09:22 PM | #6 |
How they working ... Any complaints ?
02-08-2014, 09:27 PM | #7 |
Yea I am I just PM you !
02-08-2014, 09:52 PM | #8 |
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
I'm planning on doing this conversion as well but have heard that there is a difference in the bolt sizes between the disc and old drums. Is that actually the case? 70/c20
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
02-08-2014, 10:30 PM | #9 |
02-08-2014, 10:37 PM | #10 |
Here's a couple of links that might help !
http://www.ruffstuffspecialties.com/...g/EHO5272.html http://blackbirdscustomtrucks.com/index7.html |
02-08-2014, 11:27 PM | #11 |
I used the BlackBird ones and the kit is simple to install. All bolt on.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
02-08-2014, 11:59 PM | #12 |
Did you use on front, rear or both? Curious about the rear. Thanks.
02-09-2014, 12:09 AM | #13 |
I'd like more details also! Pics, etc. Did ya go with the integral parking brake caliper? If so, any issues you might see with it holding a truck with a camper? Did you need to add an adjustable prop valve to balance front / rear - or was the factory distrib block ok?? (I assume you'd have to have an adj valve). Very interested.
02-09-2014, 10:48 AM | #14 |
Vintage 4x4s
Heres one I put together myself on the Eaton HO52 using the brackets from NW fabworks. If doing again, I would find brackets with holes already in that allow the caliper to mount at the 3/9 o'clock position. I used 78 Eldorado calipers and its true they are from a car, but those cars were huge and weighed what, 5000 lbs? Compared to the smallish 11x2 that was stock on the eaton, I cant believe I lost much if any stopping power. Caveat is I haven't had it out on the road yet, but should in a couple days.
The calipers are the same size as the stock front K20 ones but the piston is a little smaller, which is ok since the rear shouldn't do as much work as the front. Parking brake cable brackets I made to use stock parking brake stuff:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
