![]() Join Date: Sep 2013
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Pics of BBC with alternator and p.s pumps
What's the chance of getting some front on pics of big blocks?
I'd like to see the different power steering and alternator mounting positions available. When I pulled out my engine the alternator was almost sitting on the p.s pump. it looked awkward and didn't line up quite right. I've seen brackets for sale stating high and low positions so would like to get a better idea. Cheers ![]() ![]() ![]()
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
Re: Pics of BBC with alternator and p.s pumps
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
it sounds like you have the genre correct oe setup with a short water pump.
the picks above are of the later style with the long water pump. the high an low brackets that you mentioned are custom made setups too move things around. i'm sure if you look hard enough you could prolly find a high/mid/low mount bracket for the alt on the pass side for a short water pump but dont expect it too be oe looking. i am in the final steps of swapping from the chromed out lwp setup too the oe looking swp setup stuff on my bb and now my pockets hurt and i'm still not done ![]()
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Thanks guys. When I bought my truck late last year, the set up was such that the ps pump was on a dodgy bracket and the tension was supplied by the alternator sitting on top of it! Not an ideal set-up. While the donk is out and being rebuilt I thought I would research a better set-up. Its a bit beyond OE status, LOL , so that's not an issue, but I would like a more practical and symmetrical set-up.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Here is my truck with a 396 in it. It was in the truck like this when I bought it. The P/S pump is on the lower drivers side
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#6 | |
The truck is in storage right now but if you can wait a day or two I can go get some more detailed pics for you. The engine is a 1967/68 model and I was told came out of a Chevelle so I think the P/S pump was on the nine and they transplanted the whole thing into the truck.
Thanks, that would be great. I'm guessing it's cold and snowing where you are?
Here is where she sits and what its like outside now.
Nice lookin truck you have there. The snow's impressive too, though must be a pain I'd imagine.
Maybe these will help. 71 BBC 402.
Watch out for your cornhole !
![]() Join Date: Jun 2003
These are correct 72 model big block truck brackets.
![]() I got the entire setup off of an unmolested truck as a matched set.
#13 |
Sub'd. I'm looking for a passenger side low mounting option for the alternator for my BBC too. I want it low like the PS Pump. My PS Pump is the original style with the remote tank. I have took a lot of time cleaning up the engine bay so I probably will not be using it.
Danny |
#14 |
Thanks Kevin, Nice looking donk.
I'd like to have the alternator opposite to the PS pump. I have a bracket similar to your PS bracket, but when I tried dry fitting it, the PS pulley was slightly skew-wiff and the belt didn't run true so I figured it may have been the wrong bracket. Chris, ![]() ![]() ![]()
#15 |
I should be able to get you some pics tomorrow afternoon, its 1:00am here and I'm at work.
#16 |
Here are the pics of my P/S pump. From these pics can someone tell me if I have a short or long water pump.
#17 |
![]() Join Date: Sep 2011
Long....same here:
1967 C10 SWB Owner - Rustbelt Restorations |
#18 |
Long
