02-09-2014, 02:33 AM | #1 |
Anyone recommend a radiator?
Going in a '53, first time with a LS motor. Curious if anyone makes a good Rad that will cool and easy to install with in and out in a easy way to route the hoses.
Also I hear some people talk about the LS motor needing a steam port other say no... |
02-09-2014, 05:42 AM | #2 |
Re: Anyone recommend a radiator?
I used a Griffin rad from summit ra ing in my 71 $247.00
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-09-2014, 10:35 AM | #3 |
griffin.......the steam port needs to be run somewhere, but not necessarily to the rad...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-09-2014, 01:00 PM | #4 |
Freakin Awesome!
I'm leaning towards this one...
http://www.summitracing.com/parts/gr...del/c10-pickup with the built in trans cooler and some Ford Windstar EFans.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
02-09-2014, 01:07 PM | #5 |
Entropy.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-09-2014, 01:17 PM | #6 |
im going with this in my '66 (gotta take the radiator shroud off the core support)
Griffin Radiator 8-70009-LS Dominator Series... easier to run the hoses both on the passenger side and gets you a double pass. tranny cooler on the driver side though, which is kindof a bummer. also the mounting flanges will make my fit a lot easier. |
02-09-2014, 01:27 PM | #7 |
The stock radiator will keep it cool just fine.
I don't have a steam port on mine, I just tapped the top of the water pump and connected a 1/4" hose to it and the crossover tube between the front of the heads. Never had a heating issue last summer driving it in 100+* temps. |
02-09-2014, 06:27 PM | #8 |
1965 Chevy C10, 2005 4.8L/4l60
I have a champion aluminum rad. Inexpensive and cools to 650 hp
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-09-2014, 09:30 PM | #9 |
http://m.summitracing.com/parts/gri-8-00013-ls is whwt i got
02-09-2014, 10:17 PM | #10 |
Old member
I would use the factory one that you have. Take it have it cleaned and roded out good and go with it. Drill and tap the water pump and tie it into the cross over lines as most do. You can see mine in the picture.
02-10-2014, 12:39 AM | #11 |
Since its going in a 1953 I would not reuse the stock radiator. I'm doing the same swap. A lot of the guys over in the 47-59 section are going with Champion radiators. They can be had for around $200 for it and its made from aluminum. Your old radiator kept the 216 cool but its probably in rough shape. By the time you pay to have it rebuilt you could just buy the Champion one.
As for the steam port, you can tap the top of the radiator (by upper hose connection and zip tie your steam tube to the upper hose) or just tap the top on the water pump and hook it up. Its not a big deal and you should not sweat about it.
My 1950 Chevy build Last edited by Root2812; 02-10-2014 at 12:43 AM. Reason: Added the "Not" in the last sentance. |
02-10-2014, 11:55 AM | #12 |
we don't have a pattern yet for the 47-59 models, but if we can get an original, we can build one easily (and would include a discount for the person test fitting). For the steam port, I would recommend running it to the radiator. That way if your water pump fails while on a trip, you can easily swap it in the parking lot without having to also drill and tap the waterpump.
For the LS radiators, we put the correct size inlet and outlet on the passenger side, and include a steam port and trans cooler at no additional charge on all of our radiators (we are a supporting vendor here), and all of our radiators are made here in the USA |
02-14-2014, 01:51 AM | #13 |
This is a champion with 2-14" fans and aluminum shroud. I got it on eBay
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
