02-09-2014, 03:39 PM | #1 |
69 Blazer Hatch rattle
What are you guys doing to fix the hatch from rattleing so much? Drives me nuts.....
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
02-09-2014, 03:46 PM | #2 |
Re: 69 Blazer Hatch rattle
Are you missing the strip on the tailgate ? Maybe you need to adjust the latch catches.
02-09-2014, 04:09 PM | #3 |
Carpe manana
x2. My K5 lacked the strip when I bought it and the hatch rattle was quite noticeable. Adding the strip went a long way to reduce the noise. Later I added the missing rubber bumpers (one from you IIRC) and now the hatch is solid with very little noise. What hatch parts might you be missing if any?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-09-2014, 05:56 PM | #4 |
I don't think I am missing any parts.It must have drove the original owner nuts too because there are make shift pads and rub strips all around the hatch. The hatch is not centered in the opening for one thing. I think there are fore and aft adjustments on the upper hinges but not sure. Here are a few pics.
02-09-2014, 05:58 PM | #5 |
more pics
02-09-2014, 06:12 PM | #6 |
Carpe manana
Huh, it does look complete. How's the gasket quality? All the bolts tight? Are the rubber bumpers doing anything or need to be tweaked for better contact with the hatch? Is the tailgate loose or malaligned?
02-09-2014, 06:14 PM | #7 |
Carpe manana
I'm checking other posts as there is a piece on each side I don't see....
02-09-2014, 06:21 PM | #8 |
Carpe manana
I don't see these "brackets" on your hatch. Not sure if these are what contact the rubber bumpers or not (my K5 isn't here at moment to check) or if absence would increase noise:
02-09-2014, 06:45 PM | #9 |
I confirmed this on my hatch asolde. Yours is missing those cover peices on both sides of your hatch and they ride on the rubber peices when hatch is closed. Good eye Pete.
02-09-2014, 06:53 PM | #10 |
Carpe manana
Thanks Derek - maybe the absence contributes to the rattle. I have a spare set of these somewhere.
02-09-2014, 07:28 PM | #11 |
That would be cool if you had an extra set Pete, Let me know. Thanks for the help guys. Alex
02-09-2014, 08:00 PM | #12 |
Carpe manana
You bet Alex - here's the set I have. These haven't been cleaned and show light surface rust - I believe they'll clean up very nicely.
I'd part with them for $30 shipped after I check my hatch to make sure I do have them I once sold a fuel neck cover in great shape not realizing I needed one for my K5
02-09-2014, 08:08 PM | #13 | |
02-09-2014, 10:20 PM | #14 |
Carpe manana
We're all good. I ran and checked - I do have a set on my hatch. PM on the way....
02-11-2014, 06:35 PM | #15 |
The long rods inside the hatch that run from the T-handle to the catches on either side can rattle too if you don't have the little foam deadeners on them anymore.
02-11-2014, 07:42 PM | #16 |
Thanks I will take a look at that. Where can I see them from?
02-18-2014, 04:51 PM | #17 |
To see the rods you have to remove the access panel under the t-handle. You can kind of see them if you use a little mirror to see inside the hatch. If you can't see them, then you can un-clip the rod ends from the t-handle cam and unbolt the catch mechanisms on the sides of the hatch and pull the mechanisms out. The rods will be clipped to the mechanisms. The foam deadeners are little foam blocks that are attached to the rods.
02-20-2014, 05:48 AM | #18 |
Recalculating.....
Remove top...
Problem solved!
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
02-20-2014, 08:42 AM | #19 |
02-20-2014, 10:33 AM | #20 |
Recalculating.....
Small world! Another funny thing is my Blazer came from Albuquerque NM. Yea real heat wave today we may hit 50! When you head out this way over the summer let me know it would be nice to meet you!
02-20-2014, 10:49 AM | #21 |
I wish they made hatch parts aftermarket. It is very limited and the rwpop hatch itself I heard is a piece of crap as well. It's good we can find stuff from other members that still works good here.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
02-20-2014, 01:14 PM | #22 |
That's exactly what I was thinking too...wind covers alot of the noises!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
02-20-2014, 08:51 PM | #23 |
Looking forward to it Brian. I looked at your build sometime back. Your blazers are super nice!
