Old 02-09-2014, 04:49 PM   #1
Govern
upside down steering wheel
The previous owner did the jeep xj steering shaft swap, and i think while the shaft was out he spun the wheel upside down. The alignment is perfect steering is great. Its just the steering wheel is upside down and really annoying.
is there an easy way to fix this? do I have to disconnect the steering shaft and turn the wheel?
84 k10 350ci 7004r 1/2 axles 456 gears. 4 inch lift
Govern is offline   Reply With Quote
Old 02-09-2014, 06:29 PM   #2
Oldriginal86
Re: upside down steering wheel
Pull the steering wheel off and rotate it 180.
Oldriginal86 is offline   Reply With Quote
Old 02-09-2014, 06:38 PM   #3
Govern
haven't rented a steering wheel puller bc i read the wheel only goes on one way. Anyone else
Old 02-09-2014, 07:19 PM   #4
Wrecked1982
Wrecked1982's Avatar
im not sure if the horn wire will let the steering be mounted at anyplace ,but others will correct me
Wrecked1982 is offline   Reply With Quote
Old 02-09-2014, 07:51 PM   #5
bdiamond
Pull the xj shaft, grind a small divot in the bottom of the column for the bolt to go through opposite where its done now.
bdiamond is offline   Reply With Quote
Old 02-09-2014, 07:59 PM   #6
Govern
Your talking about this part right? So slid the shaft down spin the steering wheel and rebolt the shaft on?
Old 02-09-2014, 08:28 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Can't do that. The stub for the horn wire is fixed on the splines and has to line up with the corresponding hole in the steering wheel.
Old 02-09-2014, 10:59 PM   #8
bdiamond
Not quite that easy... You'll have to grind a notch to reinstall the bolt, but yes, that's what needs to happen.
Old 02-09-2014, 11:25 PM   #9
bnoon
Boy I'll bet the previous owner that installed that was cussing himself!!!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 02-10-2014, 10:07 AM   #10
What's up with "the XJ steering shaft swap" anyway? New one on me.
Old 02-10-2014, 06:51 PM   #11
gramps77
Holy cow, more than 45K posts and a new one for Special-K. enlighten me as well please. What is this XJ mod?
gramps77 is offline   Reply With Quote
Old 02-10-2014, 07:04 PM   #12
Your41Plague12
Your41Plague12's Avatar
It eliminates the factory rag joint on your steering shaft, which in turn eliminates a lot of the typical steering play in these trucks. From what I hear it makes a world of difference.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 02-10-2014, 08:34 PM   #13
Govern
I really cant believe how nice the truck handles w/ the swap. upside down steering wheel is annoying. Is loosening the pitman arm and turning the wheel then reattaching the pitman arm another option? I dont really want to drop the shaft and grind another notch on the column.
Old 02-10-2014, 08:52 PM   #14
tylervalo
I did it on my previous truck, it provides more positive feedback.
tylervalo is offline   Reply With Quote
Old 02-10-2014, 09:07 PM   #15
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
could you post some pictures of this shaft installed.. say close up of each end and an overall pic?
thanks,
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-10-2014, 09:15 PM   #16
bdiamond
The pitman arm idea wont work either. You'll have to pull it. Its not that big of deal to fix it. I did mine with a Dremel, but a regular grinder will fit in there if you're careful. It doesn't need much notch, .060 maybe?
Old 02-10-2014, 10:40 PM   #17
Huh,never felt there was any issue with any trucks I've had. Slop? What slop?
Old 02-10-2014, 10:50 PM   #18
Tx Firefighter
For those who don't want to go with an XJ shaft swap, I wrote an article the other day about rebuilding the stock GM rag joint to alleviate any slop that's grown over the years and miles.
http://67-72chevytrucks.com/vboard/s...d.php?t=614332
Old 02-11-2014, 02:22 AM   #19
Irish1941
Irish1941's Avatar
The Jeep joint or XJ swap as it's called is, like others said to eliminate the rag joint. Comes from the 84-92 plain Jeep Cherokee.
Grand Cherokee used different steering shaft.
Instead of the rubber rag joint, it's two u-joints, slip shaft and an isolator.
It's nearly a bolt on, The lower joint slips on the steering box and the upper will go the column but you need to make a groove in the column shaft for the pinch bolt to pass through. Takes all of 20 minutes to swap in. Best thing I ever did to my trucks.
A friend did it to his 2wd 502 SB and he isn't nice to his truck. Said night and day difference in steering wheel response.
I can post some pictures tomorrow if need be.
Irish1941 is offline   Reply With Quote
Old 02-11-2014, 12:18 PM   #20
gramps77
Mine doesnt either.
Would this be more helpful with manual steering trucks?
My power steering is great. In fact, its almost TO EASY. can steer with a pinky if you want and very responsive.
This looks to be something similar to the set up I installed in my 65 Nova when I did a rack and pinion swap
Old 02-11-2014, 03:20 PM   #21
Billy81
Billy81's Avatar
I wish i would of found this sooner it would of saved me $80
Billy81 is offline   Reply With Quote
Old 02-11-2014, 06:07 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
replaceing the Rag joint sure helped tighten my 78 up BUT
dorman aftermarket replacement left mine upside down
called ,
them: shouldn't happen,first they seen it...
me: ok but the keyway is on the wrong side....
them: steering box musta been changed?
Me: I don't think so
them: just turn the wheel around....
me: No,nothing was turned,and the wheel can't be,cause of the horn
and I ordered others to check,same part #/same way
other part# different size...
here it is,
it's listed ,says fits 78 Jimmy
(note: was told pic is just simular,not the one)(bolt direction is right in pic tho)
"check fit" not found....
and yes it drives fine,just very annoying
they never even mentioned the "kit" fix
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-11-2014, 06:24 PM   #23
Tx Firefighter
The only reason I chose to rebuild my coupler versus replacing was that it was about 40-50 dollars cheaper. I guess I just lucked out when I chose that route. Dorman definitely crapped the bed when they cast their replacement as seen in the pictures above.
My coupler rebuild article looks to be a dud. I had written it up as the first of a series of "Back to Basics" articles but there was an issue with moderation and it got renamed and screwed up. I had hoped to do an entire series of short tech articles, all entitled "Back to Basics - (Fill in the blank)........" .
Old 02-11-2014, 09:00 PM   #24
boatpuller
boatpuller's Avatar
Yes, I agree...If you got slop the rag joint needs relaced or your steering box is worn depending on your definition of slop. They didn't come from the factory needing a "swap". The swap is accomplishing the same thing that a new rag joint would.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 02-12-2014, 07:21 PM   #25
Billy81
Billy81's Avatar
After following some of your builds i think it would be a terrific idea i am sure quite a few of us could learn a lot from it. Your attention to detail is impeccable anyone who doesn't know what i am talking about should take the time to read through Tx's build threads.
