Old 02-09-2014, 07:46 PM   #1
eric8
Need help deciphering grease pencil marks
Going to detail my engine bay so I'd like to preserve all the factory markings. Apparently, the guy who wrote the numbers on my truck was having a bad day, was a sloppy writer, didn't give a s#it, or all of the above, because I can't make heads or tails of his doodling. The truck in question is a 1972 C10 Deluxe. First pic is on the drivers side upper firewall area. Looks like "740 BLK" or "940 BLK". It gets a little more confusing on the passenger side forward inner fender (just outboard of the battery box. Is it "43"? "413"? Has he marked through the number "1"? Maybe changed the 3 to a 1? What do these #s mean?
eric8 is offline   Reply With Quote
Old 02-09-2014, 07:47 PM   #2
tommys72
tommys72's Avatar
Re: Need help deciphering grease pencil marks
I see no pics?
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 02-09-2014, 07:49 PM   #3
eric8
Sorry, this one is the first pic by the firewall area.
Old 02-09-2014, 07:51 PM   #4
tommys72
tommys72's Avatar
One of these smarter members can tell you what the mean. Trim levels and paint codes and whatnot. I think it looks like 940 and 43. The one looks scribbled out
Old 02-09-2014, 08:11 PM   #5
Tinkermc
could b inspection numbers from the employee that did the inspection.
Tinkermc is offline   Reply With Quote
Old 02-09-2014, 10:47 PM   #6
71 super
71 super's Avatar
Best way to check numbers is as you pull it apart they should show up at other locations. In the case of my 68 they were on insides of both fenders (820) and head gate front. I left them in place. The first number looks to be 43 by a distracted worker, the other is likely the paint code. Check it against the spid. Is truck a two tone black and white, with white top only? My 71 black and white deluxe two tone is code 460
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-10-2014, 08:31 AM   #7
Keith Seymore
Keith Seymore's Avatar
Hard to say on that "43" or "413" in this case.
In their defense it is kinda hard to write on the moving vehicle as it is going by. I have a hard time writing on a stationary chalk board because of its vertical surface.
Usually the numbers relate to option content on the vehicle (paint colors or trim levels, for example) and are a heads up to downstream workers.
Numbers are also often the general assembly build sequence number. This is an attempt to keep the components conveyed to the main line from remote locations in order (or to verify that they remain in order). Examples would be radiator support, hood, fenders, rear axle, front axle (or front suspension assembly) and tire/wheels. Typically the last two or three digits are written of the full GA sequence number (ie, the full number might be "123456" but the operator would write "56" or "456" on the components).
My own truck was number "87", as discovered on the hood, radiator support and grille.
Supervisors and inspectors do not normally write on the vehicle itself to indicate their approval (although I have seens some ink stamps indicating a "pass"). They use the Inspection Ticket (bundle of paper tickets) and either circle the offending item or buy off on the repair with their coded hole punch.
Lastly - for Fremont builds: those guys practiced some straight up graffiti. These are the most personal marks I've seen in 35 years at GM assembly and 50 years in the hobby - other than a lady named "Linda" who signed several years of glovebox doors on Pontiac F cars:
http://67-72chevytrucks.com/vboard/s...d.php?t=607102
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
