Old 02-09-2014, 08:28 PM   #1
kxmotox247
kxmotox247's Avatar
Moving your front crossmember forward - Anyone have a good write up?
So I've seen mention of this and I know it would require a lot of work. Moving it forward about an inch gets the wheel centered in the fender, right?
Does anyone have any good write-ups of the process involved?
kxmotox247 is offline   Reply With Quote
Old 02-10-2014, 01:20 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Moving your front crossmember forward - Anyone have a good write up?
It should be centered without moving anything.... Unless I am missing something.
LockDoc
Leon
Old 02-10-2014, 11:35 AM   #3
Molberg
Molberg's Avatar
Has the cab, fenders been off the frame? Maybe slid too far ahead when the mounts were torqued up. You could likely gain close to an inch by loosening mounts and workin it back.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-10-2014, 01:07 PM   #4
chopnchaneled
chopnchaneled's Avatar
If the truck he's talking about is his avatar? It's like mine and lowered which makes the
non center of the wheel well more pronounced.
Some folks use the aftermarket control arms that have more castor built in and move the wheel forward about 3/4" which make the wheel more centered.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 02-10-2014, 02:09 PM   #5
kxmotox247
kxmotox247's Avatar
I think it's more of a visual problem with our trucks when lowered quite a bit.
I found a couple of threads but none with pictures/details:
http://67-72chevytrucks.com/vboard/s...d.php?p=977387
http://67-72chevytrucks.com/vboard/s....php?p=3363109
Old 02-10-2014, 05:38 PM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=
Some folks use the aftermarket control arms that have more castor built in and move the wheel forward about 3/4" which make the wheel more centered.[/QUOTE]
Hotchkis control arms will do the trick.
Tom Vogel is offline   Reply With Quote
