Old 02-09-2014, 08:36 PM   #1
bigmac73
bigmac73's Avatar
trans case question
well i tore down my TH350 today, in the back section where the (output planet assembly) main piston sets my case is eroded/pitted where the bottom O ring seals not allowing the o ring to seal and it wore a chuck out of old o ring. is it possible to fill the erosion/pitting or do i need to get a another case.
do tranny supply shops sell new cases or should i find a old core at a junk yard?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
