Old 02-09-2014, 08:50 PM   #1
Dragracer
Frame swap
Hello all, I'm new to the site. I have a 65 chevy swb step side and want to up grade the suspension, I have a 1996 chevy truck frame I could use and wondered if anyone has done a body swap to a newer model frame? Thanks
Dragracer is offline   Reply With Quote
Old 02-09-2014, 08:54 PM   #2
Mikemelton
Re: Frame swap
I swapped mine to an 1986 GMC frame and it was a mistake. You will have to modify one or the other due to the curves in the frame and height and locations of the body mounts. So you will basically end up with a body lift like a 4x4.
Mikemelton is offline   Reply With Quote
Old 02-09-2014, 09:03 PM   #3
Dragracer
Re: Frame swap
Oh thanks for the reply I guess I should stick with the original frame and do the conversion to disc brakes
Old 02-09-2014, 09:04 PM   #4
Indian113
Indian113's Avatar
Re: Frame swap
DragRacer, there are so many upgrade parts available for our frames I would never try to do a frame change.
Indian113 is offline   Reply With Quote
Old 02-09-2014, 09:16 PM   #5
Dragracer
Re: Frame swap
Indian113, I will probably do the upgrades instead of frame swap now that I see it will be problems with it, I just had one I could use but maybe can trade it for a 73-87 frame to use the suspension parts. I am learning a lot of do's and dont's on here. A great site. Thanks
Old 02-10-2014, 01:26 AM   #6
TommyDuncan
Re: Frame swap
I've read that a frame swap is easier if you shorten a Suburban frame since it doesn't kick up under the cab like a truck frame.
As mentioned earlier, unless you are making it a 4x4 there is no good reason to swap frames.
TommyDuncan is offline   Reply With Quote
