Old 07-21-2003, 10:24 PM   #1
western star
western star's Avatar
Resetting a proportioning valve
My dual master cylinder has what I believe to be a proportioning valve on the bottom front of it. It has a little rubber boot over it. I changed a rear brake line and the fluid level dropped out of site. After filling it I made a brake application to bleed the brakes and have no air or fluid coming out of the back line. Would this valve trip some how so as to supply bakes to the front in case of failure and if so how do you reset this valve so as I can bleed my brakes. It's on a 71 Chev 1/2 ton with front discs.
western star is offline   Reply With Quote
Old 07-22-2003, 08:25 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Yes, the valve can "trip", and not supply fluid to the rears. I would fill the master cylinder back up, put the lid on, and step on the brake pedal (with both feet) fairly hard, and quickly as well. I'm pretty sure that will reset the valve. If it doesn't, I'm sure someone will know the correct way. I know it involves stepping very hard on the brake pedal very quickly, but I don't know if you should crack the bleeders open or not. I don't believe so.
Good luck.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-23-2003, 08:54 PM   #3
western star
OK I'll try that and see if it works. I don't have the truck here right now as it's in the body shop for some final work. I'll try your suggestion when I get it home.
Old 07-23-2003, 09:16 PM   #4
Shane
Shane's Avatar
it still amazes me the things you can learn on this board ... I never knew that a proportioning valve had a "resettable circuit" ...
Good call TJ!
Shane is offline   Reply With Quote
Old 07-23-2003, 09:36 PM   #5
cdowns
cdowns's Avatar
that little rubber boot should just pop off there's a pin under it while bleeding the brakes the pin should be held out (theres a special toolto do it ) i made my own out of a piece or sheetmetal
Old 07-24-2003, 07:54 AM   #6
Alex
Alex's Avatar
cdowns - don't you mean the pin must be held in? In the Chilton manual, during the bleeding process, the pin (metering pin) must be held in. Either use a special tool or have a helper with a screwdriver or similar push it back in when the brake pedal is applied.
'72 C/10 LWB 402/400
Blaine, MN
Alex is offline   Reply With Quote
Old 07-24-2003, 10:27 PM   #7
western star
Alex thanks for that tip. Many years of playing with cars and some things just never came up until now. Go figure.
