Old 02-10-2014, 04:20 PM   #1
atm70chevy
atm70chevy's Avatar
LMC bolts
I have learned from reading alot of yall's post that most of the parts LMC sells are iffy at best but I was curious if the bolt kits they sell are any good. They have a complete front sheet metal bolt kit I was looking at. Any thoughts?
atm70chevy is offline   Reply With Quote
Old 02-10-2014, 04:30 PM   #2
Lee H
Lee H's Avatar
Re: LMC bolts
I've used a few bolt kits from LMC, they are OK for form, fit, and function. I would order bolt kits from them again. Even though the kits are a little more expensive, it's nice to get everything needed with a click of a button, and not spend hours trying to source them locally.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-11-2014, 02:04 PM   #3
atm70chevy
atm70chevy's Avatar
Re: LMC bolts
Thanks for the reply. I was wanting to order the complete kit so I knew I would have everything I needed to put the front fenders and everything back together.
Old 02-11-2014, 02:09 PM   #4
leftybass209
leftybass209's Avatar
Re: LMC bolts
worst case scenario, you can always call them to see if you can get some clarification on where they come from. Like Lee stated, they work. I too have used some smaller bolt packages from other companies, and they worked as well. Best of luck to you with your decision.
leftybass209 is offline   Reply With Quote
Old 02-11-2014, 02:22 PM   #5
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: LMC bolts
Not saying "my way's best", but the way I do it is, in this order of sourcing:
1) My own stash (often requires some re-organizing );
2) My Friend's stash (trading/reciprocating/begging);
3) Local (my small town) businesses;
4) Forum Vendors;
5) Big Box Vendors.
No "better" or "worse" ways to go, I guess.
I mostly don't spend enough to make a difference to anyone.
Doing it in this order, though, I usually get to make some new friends,
keep some old ones. And it makes me happy.
For me, what's one more "click" of the mouse, one more e-mail to a
Forum Vendor/Forum Friend, or one more ride to the locally owned
hardware store?
But that's just me.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 02-11-2014, 03:23 PM   #6
c20pickup
Re: LMC bolts
anybody use a stainless complete bolt kit from the filling station?
c20pickup is offline   Reply With Quote
Old 02-11-2014, 03:25 PM   #7
Coley
Coley's Avatar
Re: LMC bolts
....love their bolts....we use them as soft chocolates at christmas!! LOL
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-11-2014, 05:39 PM   #8
burnin oil
Re: LMC bolts
LMC bolt kit. I have used some off there stuff and it was decent. The one exception was those bolts/screws that hold the door panels on for a 67-71 door. Out of 8, 6.5 were usable. Once I busted the flash out of the cross one more was usable. The last one was totally closed off before it was plated. Looked like a carriage bolt. I also had good luck with their hood hinges. Mine were not fit to be rebushed and bent.
burnin oil is offline   Reply With Quote
Old 02-11-2014, 06:04 PM   #9
69GMCLonghorn
69GMCLonghorn's Avatar
Re: LMC bolts
LMC is iffy as noted on a lot of items, but I just ordered a few odds and ends screws/bolts. They all seem fine. Just don't order things like their factory tach's or speedo's. They were worse than my original. To their credit, they sent me 3 speedo's and didn't want the old ones back. None of them worked worth a crap. After 10 minutes at 70 MPH, they'd lose about 4 MPH... how does that happen?!
69GMCLonghorn is offline   Reply With Quote
Old 02-11-2014, 07:36 PM   #10
Econman
Econman's Avatar
Re: LMC bolts
I realize it's pricey, but so far, I've ordered anything applicable from Totally Stainless in Pennsylvania.
Econman is offline   Reply With Quote
Old 02-13-2014, 12:00 AM   #11
K10 STEPSIDE
K10 STEPSIDE's Avatar
Re: LMC bolts
I ordered the complete stainless kit. They don't label everything, but they label groups so you'll know where they go. I had some left overs and some special things I had to get bolts for but having every body bolt made it very easy and faster to reassemble. you don't need to list everything and then order each piece. I would get a kit again if I needed one. If you get stainless bolts from anywhere make sure to use anti-seize. They like to bind if you try to loosen a tight bolt. (I had to break all the bolts off that hold on the front bumper be cause I forgot anti-seize.)
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 02-13-2014, 12:04 AM   #12
magwakeenercew2jh
Re: LMC bolts
Beautiful job.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-13-2014, 12:08 AM   #13
K10 STEPSIDE
Re: LMC bolts
Beautiful job.
Thanks for the compliment and the flip.
1967 chevy K10 step
2002 chevy Impala
Old 02-13-2014, 01:36 PM   #14
Econman
Econman's Avatar
Re: LMC bolts
Exactly right on the anti seize.
