02-10-2014, 07:34 PM | #1 |
Parking Brake Cable
My truck is a 72 SWB, and the PO had hacked the parking brake cable. I've replaced the the cables and hardware, but I was missing the 2 loops/guides that I assume would attach to the frame. I've seen them in diagrams in catalogs, but wasn't sure if they were only used on LWB trucks? Do I need them? Any pics of the cable routing on a SWB would be much appreciated.
I also need to find the brake cable lever that installs inside the driver rear drum, behind the shoe. Does anyone know of a source? Doesn't look like Brothers, GMCPauls, or LMC carry it. I'm thinking I might be doing some salvage yard searches... |
02-10-2014, 11:10 PM | #2 |
Moderator
Re: Parking Brake Cable
Car quest or napa will have the ebrake arm that you need.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-11-2014, 12:01 AM | #3 |
02-11-2014, 09:14 PM | #4 |
Napa does not carry that piece or the spring for it, I need one also. I don't know about carquest.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-11-2014, 09:33 PM | #5 |
Old member
I just cleaned my drivers side rear brakes today. Here is a bad picture of the cables and the rods you speak of.
The rod is right behind the crossmember.
02-11-2014, 10:47 PM | #6 |
I checked the local car quest today but no luck. I think our best bet is to find someone parting out a truck or someone who's done a rear disc brake conversion who has the drum parts left over
02-11-2014, 10:48 PM | #7 |
02-12-2014, 07:39 AM | #8 |
Old member
Your welcome,
I have it up on stands I will try and get some better pictures of them. All they are is slick rod with a circle hook on the end of it for the cable to ride in.
02-12-2014, 08:45 AM | #9 |
I have an extra long bed frame I will check it today and see if the parts you seek are there .
02-12-2014, 02:36 PM | #10 |
02-12-2014, 03:51 PM | #11 |
Old member
Some better pictures of the hangers.
02-12-2014, 04:02 PM | #12 |
03-09-2014, 05:17 PM | #13 |
Did you ever find the lever? I found a GM part number for it: 3842980 if you do a Google search you will probably find one. Also, the GM part number for the spring is 1312281
03-10-2014, 10:44 AM | #14 |
Thanks for posting the part #'s - I haven't gotten the strut or the spring yet. I hadn't thought about getting them, but maybe I need to??
Here's a pic from LMC of the lever you need in red, they have the spreader/lever/strut but have it listed for 3/4 ton trucks? Do we need it for the 1/2 tons?? They don't sell the spring, but found the spring through O'Reilly Auto Parts - they may even be able to get the strut/lever. The final part I'm looking for is circled in blue, the parking brake cable attaches to a notch on the bottom. I need to find it for the driver's side but have had no luck what-so-ever... Last edited by TexasLS1; 03-10-2014 at 10:51 AM. |
03-10-2014, 11:53 AM | #15 |
What rear end do you have? I found it at NAPA for my 3/4 ton with a Dana 60 ?
03-10-2014, 12:31 PM | #16 |
Ah, I misunderstood which part you needed. Yes, I need the part circled in red. The part numbers I posted are for that part and the spring that fits over that part. I don't know where to get the part circled in blue. I will see if I can find out for you.
03-10-2014, 01:01 PM | #17 | |
Thanks for keeping an eye out for me! I'm glad you were able to find the parts you needed!! |
03-10-2014, 01:04 PM | #18 |
The part numbers I posted were for the strut and spring. Near as I can tell, the part numbers for the emergency brake levers that you need are 15594177 for LH and 15594178 for RH. Hope this helps.
03-10-2014, 05:27 PM | #19 |
Sir, you are a gentleman and a scholar!! I was losing my mind trying to track this down. I appreciate your help more than you know!
03-25-2014, 06:26 PM | #20 |
Bringing up an old thread, but I'm realizing I need the spreader bar/ strut that's circled in red above. Were ya'll able to find this for the 1/2 Ton 11" drums? I can't get the part numbers to bring anything up and I'm not sure if the LMC part is correct for 1/2 Ton...
