Old 02-10-2014, 08:10 PM   #1
CHIEFWAHO
CHIEFWAHO's Avatar
Advice? When to install CAM? Before or after swap?
I plan to put a CAM in a 5.3L that I am swapping into an 81 C10 SWB.
I have not heard the motor run, (supposed to have around 60k on it).
I damn near have the motor tore down just checking to make sure all looks good (heads and oil pan are off).
But I am wondering when I should install the CAM??????
It would be easier to do it now while I have the engine on the stand.
But would it be better to wait until the swap is done and know I have a good running motor and any bugs worked out????
Your thoughts appreciated!
CHIEFWAHO is offline   Reply With Quote
Old 02-10-2014, 08:14 PM   #2
truckdude239
truckdude239's Avatar
Re: Advice? When to install CAM? Before or after swap?
Do it before you put the motor in the truck these ls motor done normally go bad mine sit for u months in a wrecking yard then almost a year while swaping and still fired right up
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-10-2014, 08:22 PM   #3
pwradder
pwradder's Avatar
i'd do it now if i were you, it sucks taking stuff apart that you just put together! if everything looks good that you can see now-you should have nothing to worry about.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 02-10-2014, 08:59 PM   #4
jamesjones
Freakin Awesome!
jamesjones's Avatar
I'm in your position myself. I think I've just decided to install it and run it for a while to see how I like it. My Blazer has been down for almost a decade though so I'm anxious to get it on the road.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-11-2014, 11:49 AM   #5
Matt Cramer
If you know you want to install a cam (and valve springs), do it before putting the engine in the chassis. As long as all the cam lobes on the original engine look to be in good shape, I wouldn't worry about the condition of the engine too much - worst case is you may have to put the cam into your next motor.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 02-11-2014, 11:52 AM   #6
Hart_Rod
Hart_Rod's Avatar
Now.
Hart_Rod is offline   Reply With Quote
Old 02-11-2014, 12:13 PM   #7
littlevictories
i'm in a similar spot as you and i'm gonna get it swapped and running as a stocker.
get into the learning curve with tuning on a stock mill and then tune the bolt-ons as I go
well that was the plan until I was offered a killer deal on a p1sc....goodbye all my money forever...
littlevictories is offline   Reply With Quote
Old 02-11-2014, 12:20 PM   #8
imjeff
imjeff's Avatar
I would get the stocker running. Changing too many things at once is often a recipe for disaster. It would be hard to go back to the person that sold a bad engine to you after you've swapped a cam. Besides, it would be good to have a comparison with your new cam to stock.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-11-2014, 03:21 PM   #9
Custom 68
Custom 68's Avatar
all valid points however I would also do it now before the install especially if you are going to do it soon.
I ran mine stock for a year or so before the swap but I ended up pulling the motor again to make it easier.
I would do it now.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-11-2014, 04:07 PM   #10
Wasted Income
Boosted Member
Wasted Income's Avatar
Why is this even a question?? If you have the parts already (cam, springs, pushrods, etc) do it now.
I've swapped around 7-8 junkyard LS engines...and have never gotten a "bad" one. If it's "bad" he'd already know, as far as he says he has it torn down.
Even my "bad" busted up turbo motor ran pretty awesome with 4 bent rods, and 5 cracked pistons.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-11-2014, 04:33 PM   #11
imjeff
imjeff's Avatar
I guess I've never had the income to waste (yes, an intentional reference to your screen name). Putting a bunch of good parts in a busted engine seems like false economy to me. Buying a new truck might be the answer for those in a big hurry, but I'll keep my old stuff and make sure it's right....even if I have to pull the motor apart twice. My Jeep build will be completely mechanically put together to make sure everything works. Then I will tear it all apart to do the final powder coat and paint. It's the price of driving cool custom stuff, isn't it? To each his own.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 02-11-2014, 05:03 PM   #12
Wasted Income
Boosted Member
That was (is?) my plan with my Blazer...build it once and drive it to shake the bugs out...and to make sure there is no additional welding, grinding, holes to drill etc before blowing it all back apart for body work and powdercoat.
However, it may stay just as it is, during "mockup" phase for another few years at least. It's just too much darn fun to drive as it is.
But yes, I understand your reasoning.
Turbo diesel
Old 02-11-2014, 05:08 PM   #13
imjeff
imjeff's Avatar
I absolutely reserve the right to keep my stuff in "mockup" phase indefinitely! Lol!
Jeff
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
