Richmond lockrite? Opinions
Thinking about installing a Richmond lockrite in my truck. Currently have the ol 1 tire spin syndrome rear end.
Anyone out there have experience with theses? Good? Bad? Thanks
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Re: Richmond lockrite? Opinions
I have a Powertrax in my '48 (12 bolt car rear end) that I installed close to ten years ago. I love it but it does make some noise when it locks up after going around a corner. It's also a bit jerky when it locks back up. Make sure you don't shift going around corners or the rear usually starts sliding around trying to swap ends
I think there are new ones that are a lot smoother |
So you had no issues except for the noise and jerky feel? Which new ones are smoother?
An Eaton Posi uses spring loaded clutch discs to tie both axles together instead of a dog clutch so it is smoother BUT, stand on it or shift when in a corner and it will still bring the rear end around. For my money that's the best of all possible worlds.
2WD Jimmy
![]() Join Date: Mar 2005
ttt
Anyone else using a locker on their rear end? How difficult are they to install?
I've put them in several trucks, some mine some for other guys. They put the power down but do make some snappin noises. As long as you keep constant power to the rear it is quiet but with a standard trans if you push the clutch in it will make noise. It doesn't bother me because I know what it is but at a cruise in where some of the guys just buy a car and have no clue you'll get some strange looks. I really like the ones I've driven. In a sharp turn on warm blacktop with power to the vehicle the inside rear tire will try to make the same number of turns as the outside causing the tire to chirp a little. As I said before the issues are small compared to the benifits and ease of installation.
I might have to try one out. I don't know anyone with one installed to hear them. Maybe I'll check YouTube for a video. Also thought of installing a posi unit, but that is more expensive. Trying to keep the costs down.
Probably be cheaper just to buy a posi setup for your rear or another rear rather than a lunchbox locker. Then you have no clicking.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
Yea. I think I'm go that way too and pass on the clicking. Thanks everybody for your input.
