![]() Join Date: Jul 2007
1968 GMC 3 speed trans
I purchased a 1966 C-10 truck. I was wondering if a 1968 3 speed trans has a syncro 1st gear. The 1966 trans does not but I do have a 1968 trans that looks like the same trans. I am not too familiar with these 3 speeds.
Roadtrip!
![]() Join Date: Feb 2003
Re: 1968 GMC 3 speed trans
If it looks like the same size case, it probably is the same as what you already have. I think 69 is when the synchro first gear was more common. The main case is bigger.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
If your lucky you could find what they call the H.D 3 speed, I think they were behind big blocks an heavy duty apps. But they were synchro'd in all forward gears and they may have a little lower first or maybe not, but just get a good shifter for it.
The full syncro came out in 68. Like Stuff says if it looks like the other one it is. The early one had 4 bolts in the side cover. The latter one had 6 or7 & is longer.
CAN'T FIX NOTHIN
The syncro 3 speeds are long and look like a 4 speed missing the reverse the non sincro 3 speedes are small kinda round looking I don't have a pic handy ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Thanks for the info. I will take a closer look at it. I am not sure it will be worth changing if I would need to change a lot.
The manual transmission dept for GM in 60's was not one of the brighter spots. Running the standard 3 speed crash boxes thru 1968 was an imbaressment (Ford had a full synchro in '63). Finding a special option '66 -'68 full synchro is a rareity. All 1969 and newer standard 3 speeds were full synchro. THey will bolt in to your '68 bellhousing, but linkage rods and drive shaft may need to be lengthened or shortened.
