Gas filler neck seal
I just got a new gas filler seal (the rubber seal through the cab at the filler cap)- made by counterpart. It's too small and leaves unaged paint visible around it (a ring of shiny unfaded paint). Does anybody know of a better one available out there?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
![]() Join Date: May 2010
Re: Gas filler neck seal
I got one for my 69 from a vendor in Wisconsin a couple years ago. It was in original GM packaging. Try your local Chevy dealer and ask if they are still available from GM for your year.
![]() Join Date: Oct 2009
Ever come up to Winston Salem? This appears to be a GM seal:
http://www.classicmuscle.com/p-45774...l-1-34-id.aspx You can give them a call to make sure it's not a repro.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Sorry, I thought I saw '72 in your, but now I see you have a '70.
http://www.classicmuscle.com/p-45770...seal-2-id.aspx
#5 | |
I did get official GM door pins and bushings though. I hate that those guys are closed Saturdays. I had a buddy that works in kernersville run over there at lunch today and pick up my order for me.
#6 | |
I see you have power drum brakes.... Did you add the booster or did the truck already have it? Added: whoops, see you have it listed as an upgrade- how do they compare before and after the booster?
My wife works at a chevy dealer.... I might get her to try parts tomorrow and see if I get lucky. Anybody got a PN?
Answered my own question.....3886792.....
project: "my happy mess" |
#10 | |
I didn't know there were different ones for different years. 71-72 are different than the rest?
#12 | |
Adding a booster obviously doesn't make the brakes any better...you just don't have to push very hard. The only reason I put the booster on was because I wanted to eventually go with discs.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar Last edited by NC67Chev; 02-10-2014 at 10:23 PM. Reason: Added info |
#13 |
See post 4 in this thread for GM part numbers.
http://67-72chevytrucks.com/vboard/s...d.php?t=115346 The link to the vendor where I got my GM grommet a couple years ago is below. The grommets are near the bottom of the page with the GM part numbers. Give him a call and find out if they are still GM issue. http://67-72chevytrucks.com/vboard/s...d.php?t=115346 |
#14 |
Ya i ordered one thru Ecklers Truck parts. It cracked and fell apart in less then two months. Let me know if you find a good one.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
#15 |
Speak with Wes at Classic Heart Beat in Washington he is a board vendor and I believe he has them custom made and they fit!
Kev's-C-10 ![]() |
#16 |
The GM grommets being sold now days (bar code packaging) do not hold up well, I went through two of them a few years ago, cracked in the sun in just a few months. I now have one from Classic Heartbeat, no signs of cracking or weathering so far, it's been on little over a year.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
