Old 02-11-2014, 12:17 AM   #1
MadRatt
MadRatt's Avatar
Pic's of stepside air tank install's
Hey guy's. I have a 5gal air tank that I'm having a hard time deciding on a mounting location for under my step side bed. I don't want it to be visible if possible. Any Pic's of your underbed stepside tank installs would be appreciated. Thanx
If you ain't living life on the Edge....
Your taking up entirely to much space!!!!
My 64 Stepper Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=586792
MadRatt is offline   Reply With Quote
Old 02-11-2014, 07:08 AM   #2
jesseo
jesseo's Avatar
Re: Pic's of stepside air tank install's
I am in on this. This is my next project too. I was thinking maybe under the bed where the spare tire would be. My tank is still in the cab.
jesseo is offline   Reply With Quote
Old 02-11-2014, 10:28 AM   #3
kieth
kieth's Avatar
Well I do not have a stepside but here is how we mounted my air tank on my 66 Fleetside (swb)
drivers side front just under the cab, brackets of course mounted to frame....
http://kieth.smugmug.com/Trucks/66-GMC/i-gqt9LcM
How much room do you have at this location with a step side bed...???
kieth is offline   Reply With Quote
Old 02-11-2014, 04:04 PM   #4
MadRatt
MadRatt's Avatar
Thanx for the reply. That's where I'd like to put it but unfortunately the step of the stepside is right there so it don't work.
I'm thinking in the back behind the relocated gas tank and rear bumper but not sure if its doable since the bed is on horses at the moment. might be a tight fit.
Old 02-11-2014, 05:05 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I’m not familiar with air tank mounting, but is that something that would fit in the space where I have my mufflers mounted, in front of the axle:
They are not easily seen with the tires on the ground.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-11-2014, 05:51 PM   #6
forestb
forestb's Avatar
Or right here under the doors
forestb is offline   Reply With Quote
Old 02-11-2014, 06:46 PM   #7
slowcpe
slowcpe's Avatar
I'm not sure the difference between body styles but I'm faced with this issue myself on my '67 stepper. I looked into under the door like above pic from forestb shows. If my measurements are correct, the tank will hang down below the frame slightly. I could be wrong or your truck may have more room.
It seems one of the best spots is where the spare tire goes unless you are either planning on keeping the spare or install a under-bed gas tank. I'm planning on doing the latter. My "plan" now is trying to use the Porterbuilt tubular rear crossmembers and mount the air tank on the back crossmember between it and the rear bumper. Haven't seen or heard anyone doing that but if my measurements are correct it "should" work but may be slightly visible from the back. We will see.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 02-11-2014, 10:59 PM   #8
MadRatt
MadRatt's Avatar
Problem with this spot is the tank would be visible hanging below the rocker. but thanx for the reply
Yea mine seems to be a little bigger of a tank at 5gals and would be visible below the rocker
already have the underbed tank so behind it and between the bumper is where I was thinking. I was just hoping someone else had done it so I could see if it looks good or not before I start hacking up new mounts and all. seems like everyone with a stepside mounts their tanks in the bed.
not enough room for the tank I'm running and to many variables with moving trailing arms and drive shaft. but thanx for the Idea..
Old 02-19-2014, 06:27 PM   #9
MadRatt
MadRatt's Avatar
C'mon bagged stepper brothers!! There gotta be someone with pic's of their underbed stepper air tank install.. Anyone? Bueller? Bueller?
Old 02-19-2014, 07:32 PM   #10
wayno
Bagging my stepper but I have the huge notch in the rear so it opens up all kinds of opportunities.... so I guess it depends on how low do you go...
64 Step Side - The Mistress
wayno is offline   Reply With Quote
