02-11-2014, 12:18 AM | #1 |
Whats your list?
When you first brought home your truck what did you do to it before taking it for a serious drive.
Im going to take a decent 500 mile road trip once the weather improves so my 69 and i get to know each other a little better. I'd love to here what your guys rituals are to give you the confidence that your truck is good to go. Cheers Earl
1966 GMC ShortStep |
02-11-2014, 12:40 AM | #2 |
Re: Whats your list?
Normal things...fluids brakes belts...mine had sat for the better part of ten years, so it got the major tune up and the normal stuff. Drove it about a thousand miles (nc to mo) about 6 months ago. She didnt skip a beat
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
02-11-2014, 12:56 AM | #3 |
I usually like to change fluids, belts and hoses. Look around underneath, make sure you've got good brakes and brake pedal, good battery cables, good battery and no fuel leaks. The good news is that road trips aren't too hard on equipment. Have fun!
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
02-11-2014, 01:07 AM | #4 |
Vintage 4x4s
On the latest K20, I started by yanking the seized engine and seized trans, then gutted the cab, followed by rebuilding pretty much everything. Still working on it. Brakes, driveline, heating system, fuel system, wiring, door handles, all replaced.
Before and how it looks now:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-11-2014, 10:03 AM | #5 |
^^ big difference already
02-11-2014, 12:43 PM | #6 |
the boat guy
Put gas in it, I drove 300 miles home. Then BRAKES! It would stop but I thought I was going to rip the steering wheel off.
Fluids, tune up, and a good inspection.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-11-2014, 01:23 PM | #7 |
Plugs, fluids, filters, belts, pads, rotors, bearings, battery, alternator, wires, hei, shocks, tires, grounds, battery cables, rebuilt carb, exhaust manifolds, intake manifold...I guess I'm ready for a road trip!
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
02-11-2014, 01:27 PM | #8 |
Not with all the ice you're supposed to get.... Back to the regularly scheduled threa
02-11-2014, 01:32 PM | #9 |
Doah! I forgot the snow tires!
02-11-2014, 01:34 PM | #10 |
When people say fluids, I also include differential fluid in that. The last 3 older vehicles I've worked on were either low, had horrible fluid, or a combination. Also I think it'd be obvious to change wheel bearings if you heard a noise on a short trip. My truck had the bearing race welded to the spindle from excessive heat.
02-11-2014, 01:48 PM | #11 |
Yes, leftybass! I forgot ball joints and lube...lots of lube.
02-11-2014, 05:54 PM | #12 |
When I bought mine,I didn't have a list....and proceeded to drive it 1200 miles back home. So after 30 miles and realizing the cam was wiped I just had it towed the other 1170 live and learn
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
02-11-2014, 07:47 PM | #13 |
Mine had sat under trees for 3 yrs when I got it. I had to put new wheel cylinder in the rear, brake shoes and kits on both sides. I had to put a new carb on it to get it to run. The old Quadrapuke was toast. Then I limped it 20 miles home as the points were sticking and it would barely run.
Once I got it home, I TOTALLY disassembled the entire truck down to a rolling chassis before taking it to have a new suspension installed after having everything about the rolling chassis powder coated. Even the rally wheels, bumpers, brake drums, rear end, all of it... Now after sitting for 2 yrs without touching it, I have taken the engine apart and have it at the machine shop. I am so ready to move this build forward so I can see daylight at the end of the tunnel and can style and profile! |
02-11-2014, 09:10 PM | #14 |
How about take it down to nothing and rebuild it with all new parts, just to make sure you don't forget anything. lol
02-11-2014, 09:33 PM | #15 |
If you do't have a factory service manual at least download a copy and review the proceedures and recommended services. My recommendation would be to perform a major service to baseline the truck. Remember the more difficult or bothersome a service line item seems to you, the less likely it has been done in a long time! All fluid levels and conditon are a must. Bearing lubrication/clearances and brake leaks or seepage should be high on the list.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-12-2014, 02:33 AM | #16 | |
Great responses everyone.
