![]() Join Date: Sep 2013
To Tape or Not To Tape...Please help...
I am replacing my heater hose manifold adapter with a new one. Old one did not have Teflon tape on it. I am also replacing the water pump plug. It Is Teflon taped.
Do I need to tape them?? Thanks |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: To Tape or Not To Tape...Please help...
I would put tape or some kind of sealer on those. The temp sender is the one you don't want sealer on
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
There is no harm in taping it correctly, only the added benefit of no leakage. In the end, if you didn't want it to "show", you could always take a razor blade and run around the excess, for a clean finish. In my mind, benefits without repercussions are a thumbs up! Good luck and hopefully others will share some insight as well.
![]() Join Date: Jan 2001
Third vote in favor of tape. I recommend the heavy-duty type rated for gas and oil - it's usually yellow.
rather be safe than sorry,. I'd tape.
![]() Join Date: Feb 2013
yep, I use the yellow gas tape on anything that is going to see any temps above 125deg. It is 4 times the cost of the white but i have never had a leak using it.
