Stock Tac ?? Will it work
I'm doing a LSX swap and wanted to know of there is any way to get my stock tac to work.
Thanks !
1969 C20 CUSTOM "RUMBLEr" |
Re: Stock Tac ?? Will it work
I kniw that there is I am just unsure if it is as simple as running the tach wire from the harness to the back of your tack. The biggest issue if you swap your trans is the speedo. It can be done but isn't cheap. I will be going with a digital dash when I do my swap.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
Digital dash ain't cheap lol well a good one at least
Old member
As I PM'ed you I don't know about the tach except that it should work. A cheap way around the speedo is buy a www.speddhut.com GPS speedo like I did. It is wonderful. It doesn't care what size tire you run it's dead on the money.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
