core support bushings - 68 core on 71??
which bushing kit should I go with, 68 or 71? putting a 68 front clip on a 71 suburban. both the 68 and 71 bushings were missing when I bought it so I dont know which to buy.
help appreciated |
Well, my truck is a '71 but the chassis is a '67. The frame mounts look a little different between the two, but I'd go with the '71 bushings for a better fit the holes in the core support are the same from what I can see. Hth,
Ben |
![]() Join Date: Mar 2009
Re: core support bushings - 68 core on 71??
I have a "69" and using a "68" frame. "69" to "72" uses a different frame mount and the support is different. You will have to us a "68" support and frame mounts. The 68 mounts are smaller than the later years in the support bushing holes
