Old 02-11-2014, 02:50 PM   #1
texasld
texasld's Avatar
454 BBC Swap
I know this forum is riddled with 454 swap threads and build logs, but I haven't quite found what I have been looking for.... So, Here we go.
I have a 1969 C-10 with a later model 350 crate sitting between the frame rails. I have been told that the motor runs, but I haven't been able to verify for many reasons. BUT, I have some ideas for my self.
My manager has a 1999 Suburban 2500 that is fully functioning other than the trany, that's no big deal. He will sell it to me for $1500. My idea is to take the Vortec 7.4L (454) out along with many other parts like all the serpentine system, the AC Compressor (wanting to add to a Vintage air system later), FUEL INJECTION, ECU, wiring harness, maybe even the seats and console... Etc. Then sell off the parts I don't use on CL.
This is my inspiration for the 454. This is a user on this board's truck. (I can't remember who it is) But I would like for it to look a lot like this. May not be possible unless it has a TBI, which it doesn't.
Would it be worth it for a parts vehicle?
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 02-12-2014, 09:17 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: 454 BBC Swap
How many miles on it?
Tom Vogel is offline   Reply With Quote
Old 02-12-2014, 09:58 AM   #3
texasld
texasld's Avatar
Re: 454 BBC Swap
Somewhere in the upper 2's lowers 300,000's I'm planning on a full rebuild, a over bore, and a cam. This will of course will lead to an ECU reprogram too.
If I were to pull a 454 out of a Junk yard and buy an Ez EFI system I'm already looking at close to $2000 with out a rebuild or any of the running gear.
1999 Jeep TJ
Old 02-12-2014, 12:30 PM   #4
MARKDTN
Re: 454 BBC Swap
You can do what you are talking about doing. It is possible to put a late 454 in an early vehicle. I assume you will use the 4L80 trans and have it rebuilt? If was going to go to all the trouble, I would go with an LS. But either way it would definitely be fuel injected. You are on the right track.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-12-2014, 02:00 PM   #5
texasld
texasld's Avatar
Re: 454 BBC Swap
The LS is always a sweet way to go, but my money tree doesn't produce as much as others...
1999 Jeep TJ
