292 Heater Hose Routing ?
Hooking up a heater in my 68 GMC with a 292, any one have a picture of the hose routing ? Thanks
71 C-20 07 Magnum RT AWD |
The Older Generation
Re: 292 Heater Hose Routing ?
This maybe? #1 Or this? #2 I'm not sure it makes a difference on the six but maybe someone that is sharper than me on them will chime in.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-11-2014 at 10:39 PM. |
![]() Join Date: Feb 2002
I might have a shot...
The question is, I think, is should the water pump up through the core or down through the core. I'm sure there is a correct way, but I doubt if it makes much difference overall.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
The correct flow is from the t-stat housing to the lower heater core nipple (the inlet). Then it runs from the upper heater core nipple (the outlet) to the water pump. While I am not positive, IIRC the HD cooling, automatic or A/C trucks returned to the radiator as did V-8s.
The reason it flows this way (bottom up) is to purge trapped air (pockets) from the heater core which would cause it to be cool.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thank you to all for the information ! Another question about the core position in its housing ? Is the 3/4 connection the inlet or the outlet ? My wife is yelling about the heater parts all over the kitchen table !.......
The 3/4 " tube is the outlet.
![]() Join Date: Jul 2015
Is this correct?
1.to small inlet of core 2.to large outlet of core 3. to radiator
1963 C20, small window, long bed 292, 4-speed |
#9 | |
Moderator
![]() Join Date: Aug 2017
Correct, here is my 67 c50 for reference.
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
Ok. Thanks.
The only difference, mine has only one threaded port on the passenger side of the thermostat.
Moderator
Here are the differences over the years in thermostat housings and water pumps. The pics are not mine*
